Results 1 to 13 of 13
    jcb
    Sep 2005
    uk
    4,077
    18x8j TT alloys on a B5 Avant...possible
    anyone running these? do you have clearance issues?
    They are ET33 if I am right
    Jul 2005
    2,488
    Re: 18x8j TT alloys on a B5 Avant...possible
    unless you get PCD adapters, theyre not going to fit.
    if its the RSTT design you want, just get the RS4's.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    You can't run TT rim's on the A4 the stud pattern is incorrect.
    jcb
    Sep 2005
    uk
    4,077
    RS4 alloys are ET20 and will not fit.
    What PCD are TT's?
    is anyone running RS4 or similar OEM wheels on a B5?
    Jul 2005
    2,488
    100
    jcb
    Sep 2005
    uk
    4,077
    OK then, Let me put this another way.
    I need 18's to fit the brakes I want, I would prefer 8j wheels.
    What ET can I get away with on a B5 avant without arch mods?
    can't believe that TT wheels don't even have the same PCD!
    imported_kris_tdi
    some b6 models had the same wheels in 18", they will fit.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    You can get RS4 replica's quite cheaply but you need a PCD 5x112.
    Olly__K
    [ QUOTE ]
    [/ QUOTE ]
    Genuine RS4 Wheels are ET20, you need RS4 reps
    Sep 2005
    Richmond, London
    67
    I got my RS4 reps with tyres for under 500
    jcb
    Sep 2005
    uk
    4,077
    i know but they all seem to be drilled for 112 and 100 pcd.
    i don't want multifit ones
    PhilR's Avatar
    One Ate Tea
    Jan 2006
    UK
    330
    i reckon an 8 inch rim with a 20 offset will fill the arches perfectly plus the originals are so much nicer than the cheap reps
    jcb
    Sep 2005
    uk
    4,077
    thats what the RS4 ones are but everyone says they don't fit without arch work. do you know something they don't?
    Mine are 7j 17 ET35 so an 8j 18 et20 would move the rims in the way rather than out towards the arch?
    no?
