AH FabricationsSky Insurance
Results 1 to 12 of 12
    Jan 2014
    Vic, Australia
    Question Oil sump plug and filter?
    Hi, I've not long bought a new car, first Audi in the family We can't find where the sump plug to change the oil is and also want to know where the oil filter is, I've read you need a certain tool for the sump plug but am not sure if that's correct? Any help would be great in the location to find the sump plug and changing the oil, is just your usual oil fine for an Audi A4 (2000)??
    Mackleberry
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Sump plug is just a 17mm bolt on the bottom edge of the sump. Exact location depends on the engine and year.
    Required oil depends on which engine is fitted, and you didnt specify that! Same with filter location
    TD5 Land Rover Defender build
    Jan 2014
    Vic, Australia
    Hey, thanks for the reply I'm not so good with cars, my dad usually helps out but he's never had an Audi himself, it's an Audi A4/S4, 2000 model, the engine is 1.8L, 92kw output, is that all the info for knowing what I need to know?? If not, where (and at the risk of sounding a bit dim!) do I find what engine is fitted?
    Thanks so much again for the reply
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    191
    ImageUploadedByTapatalk1391593607.406295.jpgyoull find a sticker like this in the boot under the carpet. It tells you the engine code, gearbox, power, and the three letter/number codes are what should be fitted. I've decoded a few here
    X2B = National sales program Great Britain\
    B0A = Component parts set without country-specific design requirement\
    C0Z = Alloy wheels 7.5J x 18\
    G0C = 5-speed manual transmission\
    H6S = Tires 195/65 R15 V\
    J1P = Battery 220 A (44 Ah)\
    M51 = 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z\
    Q1A = Standard front seats\
    0JZ = Without determination of weight categoryfor front axle\
    1AC = Anti-lock brake system (ABS)\
    1G3 = Alloy spare wheel with original equipment tires\
    1MR = Leather steering wheel\
    5RV = Right exterior mirror: aspherical\
    5SJ = Left exterior mirror: convex\
    T5Z = 4-cylinder gasoline engine 1.8 L unit 058.B\
    0YZ = Without determination of weight categoryfor rear axle\
    3S2 = Black roof rails\
    4UE = Air bag for driver and front seat passenger\
    0G1 = Gearshift lever\
    8UB = Radio preparation\
    8GD = Alternator 90A\
    8RN = Sound package (brand sound)\
    1LZ = Front disc brakes, standard ventilation\
    3FA = Without roof insert (standard roof)\
    C6P = Alloy wheels 8J x 19 front, with 8.5J x 19 rear\
    G0K = 6-speed manual transmission\
    = code not found :-(\
    H6U = Tires 205/55 R16 91W\
    J1R = Battery 420 A (82 Ah)\
    M5V = 6-cyl. turbo diesel engine 2.5 L/110 kW catalytic converter and EGR, MVEG 2 base engine is T6T\
    0JK = Weight category front axle weight range 10\
    1AJ = Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)\
    T6T = 6-cylinder diesel engine 2.5 L unit 059.A\
    0YE = Weight range 5 installation control only, no requirement forecast\
    3S0 = Without roof rails/roof load rack\
    4VE = Two 3-point seat belts and one static lap belt in third row of seats\
    8UD = Radio "concert"\
    8GL = Alternator 120 A\
    1KD = Disc brakes, rear\
    1LB = Disc brakes, front\
    1BA = Standard suspension/shock absorption\
    Jan 2014
    Vic, Australia
    This is the sticker I found, it was in the book that came with my car, I actually saw it earlier when going through the info trying to find out the info (engine, year etc) but didn't realise it listed all that info. Thanks for writing out the codes you decoded, I have printed them out to keep for future reference and to see what matches, I'll try searching on Google for any different codes, hopefully I'll have some luck!
    "Stick a V8 in it!"
    14,900
    Drain plug should be here:
    http://www.audiction.com/app/wp-cont...-change-03.jpg
    It might be on the opposite side though, in a similar place.
    Oil filter is on the side of the engine, underneath the coolant reservoir. If you remove the tank and tip it forward you can get into it.
    Jan 2012
    Malton
    272
    type all of the codes into this web based decoder http://http://prsearch.planetvag.com/ and it will tell you all of the build options of your car
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    Jan 2012
    Malton
    272
    Jan 2012
    Malton
    272
    try that one not the link in my first reply!
    Jan 2012
    Malton
    272
    is it a good idea to use a bigger filter Kev?
    "Stick a V8 in it!"
    14,900
    I use the B6 one, which is a wee bit wider and a wee bit longer than the normal B5 part.
    Some folk use the transporter one which is bigger still.
    Jan 2014
    Vic, Australia
    Thanks for all your answers I used the web link for the codes, thanks, just got to get around to actually changing the oil now, will see how it goes, thanks again
  1. 1999 A3 1.8T Sport Oil Sump Plug socket size?
    By Mi11ar in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2014, 09:52
  2. Sump, pick up, oil and filter done, BUT need conformation.
    By cjsuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2013, 09:54
  3. Haldex Oil and Filter Change - How To.
    By Secret Squirrel in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2011, 16:06
  4. S3 2002, sump plug and washer info?
    By sprally in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2010, 21:33
  5. oil and filter change
    By Banwell in forum Tuning
    Last Post: 17th March 2004, 10:21
Tags for this Thread
