JMB RetrofitsAH Fabrications
Results 1 to 10 of 10
    Feb 2014
    Turbo kicks out to soon
    My turbo only stays on for short time. Any one know what the problem could be? I am new to the Audi family, it is a 2001 A4 Quattro Avant
    2,150
    What engine?
    Feb 2014
    4 cyl. 1.8T
    B5QUAT's Avatar
    Apr 2011
    The North
    306
    They only have a tiny turbo, so they do tend to run out of puff higher up the rev range. Change up earlier and use the available torque in the midrange or get it remapped for more boost. Is it standard? 180bhp?
    1999 B5 k04'd S4. Eibach coilovers, RS6 front brakes, RS4 Rears.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,301
    You really need a boost guage to see whats going on.
    Changing up early might "feel" faster, but (assuming ofcourse its not broken and is just standard) revving it out properly WILL be faster.
    TD5 Land Rover Defender build
    Feb 2014
    As far as I know it is stock. I just purchased it, previous owner tried to work on it and did a shotty job. The one short trip I took it on the turbo stayed on when I put the pedal down and the car felt like it had some power to it. I tried it again on the same trip and it seemed as though the turbo left as soon as it came on. I have a couple vw's but like this Audi much more, not to mention I like to wrench on cars.
    Lcd is bad so have to get it fixed, but maybe it is going into limp mode?
    Feb 2014
    I live in York, PA, do you know what I need to upgrade turbo and or how to go about remapping it?
    B5QUAT's Avatar
    Apr 2011
    The North
    306
    Like Aragorn says, you really could do with a boost gauge to check if it's producing full boost. That's a start. You might have a leak somewhere. Diverter valves and pipes are common culprits. But it could be many things really. Take it to a specialist and let them have a look. There is one slap bang in the middle of York but I can't remember their name. Maybe someone else can help with that. For a start (and it won't cost anything) have a good look round under the bonnet. Check hose clamps are tight and that you don't have any split or knackered hoses.
    "Stick a V8 in it!"
    15,301
    Sounds a bit like limp mode.
    VCDS is an invaluable tool for these cars, get one, even if its a cheapy ebay one, just so you can check for faults etc.
    I presume by "York, PA" your in the US? This is primarily a UK forum, and there are slight differences between the models. Your car will most likely have electronic throttle, whereas UK 1.8T quattros are all cable throttle. Thats a good thing though as it means you have a wider range of diagnostics available to you.
    Feb 2014
    Thanks for the help!
  1. Turbo cut out on a 1.9TDI (110) quattro 1997
    By Beef in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th June 2012, 14:15
  2. When does the turbo kick in?
    By spannah in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2008, 15:53
  3. when does S3 turbo kick in?
    By steebo888 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2007, 03:43
  4. S3 turbo kick, high revs
    By AL_B in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th July 2007, 13:41
  5. When does the turbo kick in?
    By jxm96c in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th November 2003, 09:37
