hi to everyone i am a newbe and i bought a not so good s4, mechanically its ok but i need a headlining as its all but missing. any ideas where i could get one would be great and near to bristol if possible, thx ken
Welcome. Is it a saloon or avant, sunroof or not? You will need one from a pre-facelift s4 as they have the dark headlining, unless you fancy a bit of rewiring to get a facelift one to fit. If you go for that option it opens up your search to s4, tqs or rs4 if you have an avant. There is a guy breaking a tqs in the link above, I messaged him earlier and it's a saloon, don't know location though.
oh sorry not enough info, i am a newbe not only to audi's but this aswell. anyway its a 1998 audi b5 saloon with factory fit tilt and slide sunroof in ming blue. the original roof lining was cut out because i assume the sunroof was leaking and they were too lazy to take out the headlining properly. i didnt know that i could get a different one to fit so a bit of wiring is no issue. thx any help would be great. later on i was thinking of changing turbos and software?. thx again ken
Don't worry bud, you may struggle finding a sunroof one, but don't loose hope, check Audi srs too as there are usually a couple of breakers on there. Maybe worth smashing a wanted add up on there aswell.
I might have a spare one in my parts car, interior was stripped when I bought it, but I don't think the headlining was removed. It's a FL S4 non sunroof though, so you would have to cut it out.
hi i kinda though it in such a way that it wasnt just a hole but moulded with a bit of a flange so you didnt need a trim. i may be wrong if so then it will open another way to do it.thx
