- Joined
- Nov 24, 2010
- Messages
- 15,084
- Reaction score
- 1,131
- Points
- 113
- Location
- Plymouth
- Website
- wheelsnwires.blogspot.com
Driving in to work this morning I started to list all the jobs and faults that needs doing on Audrey but as the list grew I thought it might be best to write it down and see what people has to say about it.
Plus someone might have the part needed.
Car: A4 98 Avant 1.9 TDI (AFN) Automatic.
Faults, in no particular order.
1, HVAC illumination keeps flashing randomly.
New HVAC unit and it still happens.
Different illumination feed (from the stereo, before it was from the cigarette lighter.) and it still happens.
2, Fluid leak of some sort.
Noticed over the last week or so that there has been little blobs of oily looking fluid below the car in certain places on the road. Mainly when going slow. Its more visible than normal cause of the rain and you get that pretty rainbow pattern.
I tried to work out where it was coming from due to the location of the mark on the ground but remembered I still got my under tray on, so that don't help much.
I checked the levels and the power steering was the only one that was low but I can't check the gear box fluid.
I'm going to go with the power steering fluid on this one but is there any common places for the power steering fluid to leak from?
3, gear box starting to act up when changing gear.
Many months ago gear box went in to limp mode due to a faulty sensor.
I replaced the sensor and all was well apart from the gear change from 2nd in to 3rd. This was really harsh and felt like driving a M3 SMG again (best description I could think of). I though it might be something to do with the box relearning due to a new sensor but its stayed the same with no change.
Now its kind of getting stuck in 2nd gear (I think).
Driving a long normally and stop or slow down where you need to be in first, pull away again and it revs like its in 2nd/3rd and then snaps in to 1st and causes you jerk down the road like a learner driver dumping the clutch. Its happen several times and I don't catch it it can cause some awful clunk/thud noises.
Part of me wonders if this has anything to do with fault 2 and its the box that's loosing oil.
4, Poor MPG. I think I know what it is but thought I'd put it here just in case someone else got another idea.
I think its the rubber return hoses on the injectors are leaking. They have been replaced 3 times since I've owned the car and each time its been generic rubber fuel hoses from the local motor factors. I'll pop to my local VAG garage and get some ordered up and I'll do a service at the same time.
5, Clicking central locking pump.
It clicks, for a really long time and loudly.
Its not the pump it self, cause all the doors are locked and its no longer pumping.
It sounds like a relay going mental for some reason. I've stood there for about 5 minutes and it was still clicking when I walked away.
6, Leaking EGR blank.
Hopefully a PD130 manifold and custom charge pipe will solve that.
I think that's it at the moment.
I've not had chance to do a VCDS scan yet. The joys of moving house, its all in a box somewhere.
