Badger5JMB Retrofits
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    PFL S4 rear brakes
    what would I need to fit PFL S4 rear brakes to my 110 TDI quattro?
    cheers
    James
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    PFL rear brakes are the same as your rear brakes iirc 245mm solid discs.
    You want to get 256mm FL vented rears or iirc 279mm vented A8/S8 rears.
    All should bolt straight on and utilize the standard brake hose iirc the 279mm may need longer hoses but i doubt it as i think when people upgrade to 300mm FL S4 rears the stock lines will work but they rub on the upright hence the need of a banjo fitting hose !!
    jbh
    jbh's Avatar
    TDi lover
    704
    Quote Originally Posted by Bradderz_1988 View Post
    there was me thinking the PFL s4 would have had bigger brakes..
    main reason I was thinking PFL is I know where theres one breaking.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    Yeh as above, the PFL S4 had big fronts, but the same 245mm rears as the rest of the range.
    FL S4's got 256mm vented rears.
    A cheaper/more available upgrade would be to use the rear setup from a B7 A4, some models (not sure which, but quite a few AFAIK) got a 280mm rear disk, which i'm fairly sure should bolt right up to the B5 quattro hub.
    TD5 Land Rover Defender build
  1. About rear brake upgrade.
    By Theodore in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 07:51
  2. Replies: 7
    Last Post: 3rd January 2004, 19:52
  3. rear brakes on `85 gt5
    By leebex in forum Classic Audi Forum
    Last Post: 27th July 2003, 18:23
  4. MOVED: A3t Rear Brakes....Help.....
    By richyboy in forum General Technical / How To
    Last Post: 12th June 2003, 14:43
  5. Need A3 1.8 T front and rear brake rotors specs
    By lwen in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2003, 14:57
