Chris NottEM Tuning
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By B5NUT
Thread: What gearbox oil do I need?
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Ever since I bought the derv she has had a rough sticky notchy gear change. Iv heard that the gear boxes are "sealed for life" is this statement true? And if not what oil do I use. Engine is AHU 90
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,864
    Fully synth 75w90
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Thanks bradderz
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    635
    yea screw the idea of "sealed for life" my mates old man got told that about his auto box on his 5 series.. it started not going up the box but only when it was hot. he went to bmw who wanted to fit a new box.
    I had it up my drive for a few hours and managed to change the oil in the box.. that was around 25k ago and its still not missed a gear!!
    I did want to convert it to manual but he wouldn't let me
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    1,868
    I've also change the oil on my manual gearbox, as I don't believe in sealed for life just like I don't believe in long life servicing. It was easy to do just make sure you can remove the fill plug before you remove the drain plug. Also you will need a special tool to remove the plugs like one of these AUDI A3 A4 A6 GEARBOX, SUMP DRAIN PLUG TOOL M16 SPLINE | eBay
    jbh likes this.
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Does it matter what manufacture it is? And how many liters does it hold?
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Just noticed other replies to the thread lol, sorry my bad. I dont understand why any car manufacturer would make a gearbox or anything else for that matter, sealed for life. My gearbox is currently leaving my car a pain to drive and isn't as enjoyable.
    Jul 2007
    765
    I would change the oil and put some Molyslip in.Made a big diff to my wifes old Bora on 175k when that got notchy
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Moly slip? What's that mike?
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    How many liters does it hold?
    1,868
    I'm sure I used around 3 liters, but I used a measuring jug to measure the amount that came out, and then put the same back in. I also put in an extra 100ml just to cover any slight loss over the years.
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Thanks man
  1. What tools do i need for 6 speed HCF gearbox oil change
    By Alanp in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st December 2013, 17:01
  2. What oil do i need?
    By spannah in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2009, 15:49
  3. what gearbox oil?
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th October 2008, 20:37
  4. what oil do I need to use?
    By john_cook in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th October 2006, 06:49
  5. changing the gearbox oil
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2003, 06:14
