JMB RetrofitsSky Insurance
    Biodiesel Purrrr
    Jun 2011
    London
    150
    Excessive play in rear bearing
    MOT fail for excessive play in rear bearing.
    new bearings discs and pads went on about 10,000 miles ago
    is it just a case of tightening (as described in Haynes, new split pin and grease)?
    could wheel alignment being out cause bearing to need this adjustment?
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    2,175
    No, mostly likely someone has just not tightened the nut up enough or it somehow come lose. You can reuse the the split pin and grease, if you got the Haynes instructions then it's a very simple fix.
    Biodiesel Purrrr
    Jun 2011
    London
    150
    well, 20 minute lunchtime fix...
    nut was loose, washer behind it rattled around.
    have tightened it to remove play and washer is free to slide - just!
    no chance of re-using the split pin as it was too bent but had one in toolbox
    hoping this is not over-tight because the bearing has worn too much.
  1. Rear bearings - DIY Questions
    By eg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2010, 21:24
  2. S3 Rear Bearings
    By Motormouth in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2008, 17:48
  3. rear bearing adjustment
    By tracer in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st October 2006, 15:51
  4. Play in rear ARB drop link
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2006, 06:50
  5. excessive play in front wheel - help
    By h3msy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2004, 08:17
