Monster MotorsportEM Tuning
Results 1 to 19 of 19
Like Tree2Likes
  • 1 Post By matt_simo1
  • 1 Post By Soupie69uk
Thread: water in footwell, part 2
    Jun 2012
    Essex
    59
    following on from my other thread regarding windows opening and wet foot wells i`m trying to trace the source of a leak, does anyone know if there is supposed to be a cover across the back of the engine bay were the battery is? The car is a 1998 A4 Avant 1.8 photo (1).jpg
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    Not on cars before 1999, looks ok, do you have any standing water under the battery?
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    Also have you checked where the central locking pump is for water?
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    279
    If you have water in the passenger side footwell it will probably be from the joint on the rear washer pipe.
    Take the kick plate off at the bottom, below the glove box, you'll need to pull the door seal away a bit. You'll see the pipe which should just push back together.
    If you're not getting water from the rear washer jet that's most likely the cause.
    Jun 2012
    Essex
    59
    Quote Originally Posted by Sulli79 View Post
    i`ve not had the battery out to look properly yet but it looks damp as apposed to soaking wet
    Jun 2012
    Essex
    59
    Quote Originally Posted by foursprungdugtechnique View Post
    cheers, i will check that - it was a lot of water though, after the big storms a couple of weeks ago i came out to find both front windows down so i suspect it might be a leak somewhere but i will still have a look
    Jun 2012
    Essex
    59
    where is that located?
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    Drivers side rear behind the trim, it's tucked down below where the rear lights are, it controls Windows as well so be worth checking it's all dry down there
    Jun 2012
    Essex
    59
    cheers for that i will check
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,383
    First place to look has to be under the battery.
    There are two drain holes, and they get clogged, which means that plenum area fills with water and overflows into the car.
    TD5 Land Rover Defender build
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Ah balls, I have a b6 too but didn't realise this also affected the b5. I just sorted my b6 plenum area, the battery was standing in about 4" of water
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Also worth taking a look inside your ECU box. I found water and crap had been leaking under mine as the gasket had failed.
    Nasty!
    Mo power, mo problems
    crazy88's Avatar
    West Yorkshire
    4,806
    That's my concern with my b6. There's water in the drivers footwell, I'm hoping it was from the plenum chamber, but I suspect it may be from the ecu. Looks like it's in almost the same place on both the b5 and b6.
    jcb
    Sep 2005
    uk
    4,077
    every audi I hve owned from 90 through B5 C5 has had this problem
    irritating
    leak through ECU hole
    leak through pollen filter
    leak through rear avant indicator seal (C5)
    leak through upper window seal
    useless!
    Jun 2012
    Essex
    59
    thanks for the advice everyone, i will take the battery out and check all the other things mentioned as well
    Feb 2007
    Liverpool
    1,693
    Ed, when you say leaking through the upper window seal, are you talking about windows, windscreen or rear screen?
    Apr 2011
    79
    Check where the cabin filter is situated ...there should be a plastic water drainage piece situated under the window and above the cabin filter housing... Mine was broke and leaking water directly into the fan behind the glove box! Good luck
    deejames likes this.
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    I would checl the seal around the pollen filter as some people can be a bit rough when replacing it and the seal goes.
    A4 1.8T Quattro
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,522
    My leak was from the pollen filter housing. I dried the seal out. Silicone it into its slot and smeared sealer around the face . As I had previously cleaned the mounting face I just glued it back on
  1. Water in footwell
    By 5am in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2012, 16:55
  2. Cambelt and water pump change (parts)
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2011, 20:56
  3. Water in footwell + rear washer jet not working + aircon knackered
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2011, 14:57
  4. Water Pump replacement part....
    By Wozski in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2010, 22:08
  5. Water in footwell
    By MattS3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2007, 20:58
