Results 1 to 12 of 12
    Nov 2012
    48
    2.5 AFB Glow Plug problem - advice needed
    Hi all,
    My engine seems very reluctant to start on these cold mornings, and I've done a little digging:
    Leaving the door open slightly so the interior lights come on, engage the ignition and the glow plug light comes on. Up until I hear the relay 'click' for the GPs, there is no change in the brightness of the interior lights, neither is there any movement on the dash battery gauge.
    Could this simply be a result of a blown fuse? Or are there any more likely places for a broken circuit?
    Many thanks.
    Grant
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    Can you check the voltage then current at the glow plugs?
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    Have you ever changed them?
    If they're 12+ years old they could just be dead.
    TD5 Land Rover Defender build
    Nov 2012
    48
    Hi, thanks for the replies. Yes, they were changed last year.
    I've checked the ECU box in the engine bay and both 60A fuses are fine. Any other areas?
    Nov 2012
    48
    BTW; where's the Glow Plug Relay on the 2.5 TDi and what's the number?
    Nov 2013
    Heath Hayes
    641
    Glow plug relay J52 is in position 4 on the micro-central electrics I assume that is under the dash I think behind where the main relays are located.
    Audi A4 Relay Panel Location and diagram commentary - YouTube
    This is for an A6 but the glow plug wiring is the same as an A4.
    http://www.google.co.uk/url?sa=t&rct...,d.ZGU&cad=rja
    Seems to be the bottom line of relays under the dash.
    http://www.csupomona.edu/~bvnorum/ca...fuse_relay.pdf
    karl.
    Nov 2013
    Heath Hayes
    641
    It's marked 202 I think. You can usually tell as they have very thick terminals to carry the current.
    AUDI RELAY GENUINE 800 951 253 V23134-J52-X300 | eBay
    Karl.
    Nov 2012
    48
    Thanks; I think I've found the relay it's the blue one number 202 (same as the fuel pump relay I believe).
    I was actually watching that youtube vid about an hour an hour ago
    I'm now down to finding a wiring fault; any multiplugs / connectors prone to breaking on these cars?
    Nov 2012
    48
    I think I'll buy a new relay though; just to be sure.
    Thing is though; it still clicks to engage. Can this still be defective if you can still heare the 'switch'?
    Nov 2013
    Heath Hayes
    641
    They can still be faulty if the contacts are burned. You can take the can off the relay to see whats going on inside. Best thing to check though is with a multimeter on the fuses. If you are seeing 12V there then the relay is good and the wiring up to there is good. disconnect the glow plug cap and check there next.
    you can check the glow plugs in situ, usually if they are less than 1 ohm they are good.
    Karl.
    Nov 2012
    48
    Thanks; the glow plug fuses being under the ECU cover in the engine bay, presumably?
    Nov 2013
    Heath Hayes
    641
    yes
  1. help needed 2006 tdi glow plug problem
    By quiggy28 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th March 2012, 09:39
  2. 1996 A6 2.5TDi Quattro Estate Glow Plug Problem
    By mmarks in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th May 2007, 20:13
  3. 2.5TDi glow plug problem
    By mmarks in forum General Technical / How To
    Last Post: 14th March 2004, 11:49
  4. 2.5Tdi glow plug problem
    By mmarks in forum Diesel forum
    Last Post: 29th February 2004, 20:45
  5. 1996 A6 2.5 Tdi Quattro Estate Glow plug problem
    Last Post: 4th December 2003, 19:54
