    1,873
    TDi fuel tank sender
    This morning when I left my car I had 100 mile left in the tank, when I started it up this afternoon the DIS and gauge stated 0 and the fuel light was on, I went to the garage and put £15 as I just wanted to make sure that there was some fuel for the trip back. after putting the fuel in the tank the gauge barely moved and the DIS range stated on 20 miles till empty.
    Anyone else had a similar fault, and if so did you just buy a new sender unit form Audi or did you find an aftermarket part, as looking at etka I get part number 8D0919673J and after a quick search on ebay and google it looks like an Audi only part.
    I take it best to change it when the tank is just about empty.
    Car is a 1.9 TDi AJM
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    I had the same sort of issue with mine but it seem to have sorted it self out after several full tanks.
    I did read that the sender cable splits and causes false readings.
    Wait till the tank is low,remove the sender and make sure the cables and connections are ok.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    1,873
    I brimmed the tank this weekend and gauge went to 3/4 of a tank, then over the course of a few miles the gauge crept up to full. I've rest my trip and will keep an eye on it, but so far so good.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    That's pretty much what I did.
    sorted it self out now.
    I will pull the sender out in the next several months to make sure its ok.
    1,873
    If it happens again I'll just rip it out and replace it, just could with it lasting a little longer until the weather improves.
  1. How do i drain the fuel tank on my 2.5 tdi convertible?
    By s31lew in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd January 2011, 21:44
  2. tdi in tank fuel pump
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th April 2010, 22:54
  3. TDI fuel tanks verse Petrol fwd/awd
    By Tifun in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2009, 20:19
  4. 2.5 TDI Quat won't start - electric pump in fuel tank help !
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2007, 10:41
  5. A6 2.5 TDi Fuel econ 29 mpg ?
    By rich dj in forum Diesel forum
    Last Post: 5th October 2006, 08:46
