    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    AFN TDi vac pipes recomendations
    right im planning on replacing all the vac pipes on both the avants and the leak off pipes.
    now Ive seen folk using the silicon ones wheres the best place to get them and what exactly do I need.
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    jbh
    jbh's Avatar
    TDi lover
    704
    that ones for the 1.8t not sure if the 1.9 tdi would be the same.
    Biodiesel Purrrr
    Jun 2011
    London
    150
    kit looks expensive for a bit of tubing...
    I just bought 2m of 4mm internal diameter silicone for about £4.50.
    the plastic connectors and T-pices in the kit should alreadt be in the engine bay on the old tubing, it is unlikely they would be degraded.
    test the black and white one-way-valve or check-valve that is between the vacuum accumulator ball and the tube that links to the EGR control solenoid.
    it should hold vacuum when applied to white end but allow air through if vacuum is on black end.
    (I did this by sucking on it but not recommended as it may have oil etc inside it - shouldn't but you never know)
    I still had vacuum loss in the system after replacing old tubing,
    my check-valve was allowing air through in both directions.
    Part is 046 905 291 A - £15.30
    Check connection of tubing to the previously mentioned ball.
    there could be vacuum loss there
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,018
    The black silicone hoses are fine off eBay.
    I've been using them for months now with no issues.
    There no need to replace the plastic bits unless you snapped them.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  1. a3 tdi 1.9 vac pipes
    By joe_echo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2013, 20:21
  2. 2.0 TDI EGR pipe
    By samuelt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2010, 15:47
  3. Quick Q: Common vac pipes to split?
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2010, 13:27
  4. Audi 80 Tdi Vacuum Pipes
    By ghee60 in forum Classic Audi Forum
    Last Post: 25th November 2007, 19:46
  5. 2.0 TDI exhaust pipes by PowrFlow
    By philinman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2004, 01:55
