[ QUOTE ]
Cheers for that Tim. I made the mistake of buying brand new facelift kick plates, again a stupid price!! Then I found out that I have got to cut these to make them fit. This is not an easy job hence why after 6 months they still have not been fitted. I am thinking of taking them to a joinery to have them cut due to the length and needing a guide on the saw. All good fun. JCB > be aware that if you have an early A4 the fittings for the S4 sides do not line up with the holes in the chassis.
[/ QUOTE ]
What do you mean they need to be cut? Is it because they are too wide and protrude out past the bottom of the door as I explained above? If so you could possibly do as I did and tuck them underneath the skirt. Although thinking about it, if you have the skirts fitted already they are probably bonded to the body so this would be impractical... hmmm. Someone else did this and used a bandsaw to cut their originals along their length to good effect if I remember correctly.
[ QUOTE ]
: ( not sure I wanted to see all that. looks a nightmare!
[/ QUOTE ]
/ubbthreads/images/graemlins/lol.gif
It's not as bad as it looks, these things always look a nightmare when you see them like that. It is a bit of a long process but nothing that can't be achieved with a little patience and some care.
[ QUOTE ]
just looked at a pic I have of a B5 S4.
Could you not fit the strip that goes along the bottom of the door when you removed you old ones.
This pic shows some extra strips above the ones that you have fitted.
I just assumed that the same chassis and body would be a case of removing painting and refitting the new ones.
[/ QUOTE ]
I didn't want lower door trims on mine, that's why I removed them. I think it gives a much nicer, cleaner look to the car and quite frankly I think they look gash anyway! /ubbthreads/images/graemlins/grin.gif But that's just me...
You can indeed fit the S4 lower door trims but again, like the scuff panels, they are expensive. And for the door trims and the skirts to match up properly you will need the S4 trims as they are different to the others. They come as a kit which consists of the trims themselves, mounting brackets, associated bodywork parts front and rear and all the clips and gubbins to attach them to the car and they cost a pretty penny! You can get them from VAGParts if you fancy it /ubbthreads/images/graemlins/smile.gif
Tim
