AH FabricationsEM Tuning
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    498
    3 Beeps, but.....
    After an extended period off the road, my TQS went for an mot today.
    after jumpstarting i got 3 beeps for abs, but wasn't worried about that as it cleared almost immediately.
    but on the journey to the test centre 3 beeps for oil, look at the dials and the revs are stumbling down and go to zero. so coast to the curb immediately and turn keys off, only then do i realise the engine was still running.
    only 100 yards from the test centre so i figure what the hell and start up, drive in a low gear to get revs over 2500k, no beeps, pull into garage and the rev counter dies and i get 3 beeps,
    has anyone had this before?
    is my pump knackered and the rev counter just a coincidence?
    or if the rev counter fail will the oil pressure alarm go off?
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    sounds more like some sort of wiring issue or fault in the cluster?
    maybe check for corrosion or dampness in the wiring connectors etc?
    TD5 Land Rover Defender build
    Apr 2013
    10
    Iv had the oil light trigger on my 1.8t (The big red "STOP YOUR CAR" one!!) and my revs didnt drop. As above, sounds more like a funny cluster issue than anything else. Have you checked your oil level?! Mine was pretty low hen mine triggers and I put the light down to lack of oil in the sump. A quick top up from the emergency oil bottle in the boot sorted me out.
    Jack
    2.8 30v's Avatar
    Aug 2013
    berkshire
    137
    if the battery has gone flat and be sat for a while you may have to drive the car for a few miles (if poss ) with out stopping so the car will learn the basic settings which may have been lost due to flat battery
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    498
    Yeah it's been stood a while, bit damp in the boot, so hopefully it will sort itself with regular use!
  1. Indicators beeping but no trailer is hooked up
    By S90GAV in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th September 2013, 20:19
  2. Oil Warning 3 Beeps but oil level high
    By Spatula in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2013, 23:12
  3. Oil pressure 3 beeps - STILL! But it's sweet as!?
    By Omniquito in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2012, 23:37
  4. warning beep noise but no display message
    By zeeeebo in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2011, 17:30
  5. warning beep but no picture on lcd
    By zeeeebo in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2010, 00:44
