Monster MotorsportChris Nott
Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By aragorn
  • 1 Post By adamss24
Thread: ecu swap
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    ecu swap
    right im possibly getting another A4 TDi 110 avant on a p reg now my cars an n reg so is it possible to swap over the ECU's? im thinking that the clocks aren't coded so in theory can I swap the ECU's and the the chips in the keys over? is it as straight forward as this or is it more involved?
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    Yeh i think you'd need to log into the immo with VCDS and tell it theres a new ECU, but its pretty easy on the older cars.
    You'll need to check they both use the same ECU though, as they changed them a few times over the years. N and P should hopefully be similar though.
    jbh likes this.
    TD5 Land Rover Defender build
    jbh
    jbh's Avatar
    TDi lover
    704
    yea spoke to Adams24 about it hes told me what to look for.
    my N reg has the map sensor built into the ecu so when I pick the new bus up today ( the P reg ) ill get a look at the boost pipe and see if theres a map sensor there or not.
    jbh
    jbh's Avatar
    TDi lover
    704
    while were on the subject of swapping stuff over.. are front fog lights plug and play? or do I need to swap relays or anything?
    Jul 2007
    London
    3,234
    You will need a new front bumper fitted with fogs, 2x side trims/plastic bumper guides... I have a complete fromt bumper if you need in good nick- of course it will need painting in your own color. Do you have the fog lights built into the headlights ? They are there if the lights are made by Bosch...
    FOR SALE:
    jbh
    jbh's Avatar
    TDi lover
    704
    Quote Originally Posted by adamss24 View Post
    what color of front bumper have you got Chris? ive got the facelift front bumper with fogs on the N reg so was wondering if I could have swapped the fogs onto the potential purchase
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    300
    Add craigynett on Google+
    you need the SKC from your car
    Immobilizer I ECU Swapping - Ross-Tech Wiki
    Please contact Admin if you wish to advertise your business/services on the forum
    jbh
    jbh's Avatar
    TDi lover
    704
    Quote Originally Posted by craigynett View Post
    is that the 4 digit code? does it come on a black tag with the car when its new with the mad plastic key?
    Jul 2007
    London
    3,234
    No need for SKC when adapting new ECU to the car, the SKC is needed ONLY if you swap the instruments in the cars with Immo2 or immo3. Your early a4 might even be a Immo1 which means the immobilizer is in a separate box...
    jbh likes this.
    FOR SALE:
    craigynett's Avatar
    Apr 2006
    300
    Yes it is. If you haven't got it then get someone to extract it from the dash or ecu. Can be done with vagtacho or other key programming equipment
    jbh
    jbh's Avatar
    TDi lover
    704
    believe it or not... ive got it on the quattro.. 2 remote keys 1 service key. the plastic key and tag. was pretty amused by all that
    craigynett's Avatar
    Apr 2006
    300
    Click on the Ross-tech link I posted above. It says you have to login to immobiliser or instruments to adapt new ecu
    Jul 2007
    London
    3,234
    Trust me, you don't need SKC for adapting ECU on immo 1 or 2 in the 1.9Tdi ! Americans never had the b5 with the 1.9 tdi engine so they don't really know how it works, just do as on the link on ross tech page and it works first time, every time ! Go to instruments, adaptation ch 00, read and save, then switch ignition off and wait for a minute. Repeat if necessary and also do exactly the same in the engine's ECU, adaptation, ch 00 read and save. Clear fault codes and you might have to cycle ignition on and off a few times. You know when adaptation is successful when the Immo light goes off when you turn ignition on without starting the engine ! I have been working on vag cars for a long time, there's little i don't know about them...
    jbh likes this.
    FOR SALE:
    jbh
    jbh's Avatar
    TDi lover
    704
    youre correct Chris both of them are Immo1
    I forgot to have a look at the boost pipe to see if it had the MAP sensor.
    I will check this in a bit and update you.
    jbh
    jbh's Avatar
    TDi lover
    704
    Hi Chris. after a look under the bonnet both look the same. both have the early maf plug and no MAP sensor on the boost pipe.
    so do you reckon I should be good to use my mapped ecu in the new car?
  1. MTM - Flash or ECU Swap?
    By mjair in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2007, 19:06
  2. ECU swap?
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th April 2007, 09:52
  3. ECU swapping?
    Last Post: 15th May 2006, 19:28
  4. A3 ECU swap
    By imported_ceefna in forum Tuning
    Last Post: 4th April 2005, 23:17
  5. ECU swap
    By in forum Tuning
    Last Post: 13th August 2004, 17:54
