Badger5Sky Insurance
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Bradderz_1988
Thread: no boost no fault codes???
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    right ive not really been driving the car the wife has been running it. so today I nipped up the road with it and it was flat.. its not boosting and theres no fault codes..
    ive checked the turbo boost pipes theres no splits and everything looks fine.
    the turbo actuator appears to be stuck solid.. so is this a case of stuck vanes?
    so im going to strip the turbo off tomorrow whats my best way of checking it
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Your best and only friend now would be mr muscle oven cleaner !!
    Take the egr pipe off and spray down some vac hose into the turbine housing leave it half hour the start it up get it up to temp then give it a good thrashing !!!
    PAULF likes this.
    Biodiesel Purrrr
    Jun 2011
    London
    150
    if you have the original 'braided fabric over rubber' vac lines to/from N75 they can be split or porous under the fabric.
    I had 1 split and 1 about to split - causing reduced vacuum at N75...
    just replaced them with 4mmID silicone tubing - £2 or so per meter and one less thing that could be wrong
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    Jul 2007
    London
    3,241
    If you have vag com/VCDS then you can cycle the N75 on and off in basic settings in engine, then you could see if the actuator is moving the arm. I had all sorts of faults before, broken vacuum actuators, stuck VNT, dead N75 and they not throwing codes all the time !
    FOR SALE:
    jbh
    jbh's Avatar
    TDi lover
    704
    Hi Chris ive tried a known good vacuum actuator on the turbo and its still not moving the rod. ive also used a hand vacuum pump on to the actuator and it wouldn't move the vnt lever so pretty sure its stuck.
    Im waiting to hear back about another car so I might end up breaking the N reg and making one good car out of 2 will update on this as soon as I know its going ahead. tomorrows job is to strip the turbo off and take it over to my mates work and get it stripped, cleaned and checked.
    Jan 2011
    Aberdeenshire
    646
    It sounds as if your vanes are carbonised.
    As Bradderz said, Mr Muscle it
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Aug 2013
    The 'carse of Gowrie.
    118
    Quote Originally Posted by Bradderz_1988 View Post
    Is there a slightly more detailed DIY for this available, please.
    Aug 2010
    3,136
    Nov 2013
    Heath Hayes
    951
    Why did you let the wife drive it ??. The turbo needs some heat to keep the carbon at bay. It doesn't do them any good babying them around.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
  1. Replies: 2
    Last Post: 20th May 2013, 10:02
  2. Fault code 17608 Boost Pressure Control Valve
    By Coless3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2013, 20:46
  3. do fault codes affect the ECU I.E boost
    By ryan_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2012, 23:55
  4. boost fluctuation at low revs (p1200) boost control valve fault code
    By 4rings in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2011, 07:28
  5. engine fault code p1200 (boost control valve)
    Last Post: 22nd August 2011, 17:48
