Badger5JMB Retrofits
Results 1 to 8 of 8
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    Ebay facelift headlights
    My drivers side headlight brackets were damaged when my friend/previous owner of the car clipped a hedge and last week I think I finished them off when hitting standing water at around 80mph.
    I've been looking on ebay at 3rd party headlights and have found some for approx £50 brand new. Has anyone had any experience with these and are they any good? They seem a bit too cheap for new units?
    This is one of the for sale ad's I'm watching.
    Audi A4 B5 Right Drivers Headlight Headlamp New Replaces VAG 8D0941A29AM | eBay
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    279
    Hella, the original make stopped making the headlamps. That lamp looks good enough tho. Motor factors are around £100 + VAT each
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    So probably worth a shot then? I need to do something as I have hids fitted and don't want the flapping headlight to blind oncoming drivers...
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    You can get new brackets which attach to the existing headlights to fix the mounts (Scottb5 put me onto them as I need one for mine). It seems it's fairly common, so Audi designed the headlights to be fixed I guess?
    Genuine Audi A4 1999-2001 RS4 2000-2002 Headlight Headlamp Tab Repair Kit - Left | eBay
    Seems a rip off for two pieces of plastic, but might be cheaper than a new unit?
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    Nice one. Thank you. I'll have to investigate but if it's this simple to fix the oem lights then it should be easy enough to fab up some metal brackets out of scrap to do the same job :D
    crazy88's Avatar
    West Yorkshire
    4,806
    Yeah exactly. Good luck with it, and if you sort it with your own bracket I want pics as mine is broken, but not moving about too much at the moment, so not top of my priority list.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    TBH the tabs seem a fair price when looking at the price of a decent headlight and work a treat !!
    Now would be the time to upgrade to xenons !!
    2,163
    The original facelift headlight were and are still made by valeo I just got a new set a few months back but were around £130 each. Have to stay the new headlights made a massive difference in light output, cannot believe how bad the reflectors were on the old lights.
  1. Facelift Headlights fitted...
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2006, 12:54
  2. Facelift headlight guys....
    Last Post: 6th January 2006, 23:34
  3. facelift headlight alignment
    By ultramodz in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2005, 23:44
  4. Facelift headlights
    By imported_highlander1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2004, 13:09
  5. 225 facelift headlights
    By ravi in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2004, 08:26
