Chris NottSky Insurance
Results 1 to 15 of 15
    Aug 2013
    14
    Running temps water/oil B5 1.8t
    Hi guys, just wondering what the normal correct warmed up running temps should be for my 2001 Audi A4 avant 1.8t? The oil/water gauges hardly seem to move off the 60 mark? Also the MPG seems a bit low? Wondering if temp sensors are shot causing engine to think ya always cold and over fuel?
    It's a 1.8t running an MRC stage 1 remap at supposedly 203bhp? The most MPG I can seem to get if I drive like a total granny and totally off boost is 24.8, Seems a tad low?....
    Blue 2000 golf mk4 estate, 115 TDI, cheap coilovers, gt-tdi interior, 15" steelies, stickers'n'dents!
    Silver 2001 Audi A4 Avant 150bhp 1.8t (Remapped to 185ish), coilovers, Blue RS4 Reps, Dents'n'badly rolled arches!
    Aug 2013
    The 'carse of Gowrie.
    79
    Well at least you have the oil and water temps in sync!
    Now, I'm no expert but how quickly does it warm up?? does it have a thermostat stuck open 100% [fail safe at least]???
    Aug 2013
    14
    That's the thing, I'm never really sure it has warmed up as gauges barely move. My stat is stuck?... Might invest in a new one after Xmas and maybe temp sensors.
    Any ideas what a general MPG should be on a B5 A4? Kinda thought I could get more like 30 if I drove like an OAP ;-) lol
    Seems to cost loads to run in petrol, though my other motor is a mk4 TDI PD115 estate ;-)
    1,872
    I would say a bad stat, your temp water temp should be bang on 90 and the oil should be about the same, but I see a slight rise in the oil temp when driven at speed.
    Aug 2013
    14
    Cool. I'll do the stat and the coolant at the same time as that's fairly crappy. Time to do a flush out and order some G13 me thinks ;-)
    1,872
    I flushed mine coolant a few times, filled it up with just water drove it around a couple of miles (before the temp started to rise) and dropped it, did that a few times then filled up with G13. I also replaced the expansion tank and cap when I refiled with G13.
    Aug 2013
    14
    Cool. Just ordered expansion tank, thermostat, seal & G13. Hope I can find time to do it all ;-)
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Best time to replace a stat snd get that cabin really toasty !!!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Water, 90 on dash, oil between 80 to 90 takes bout 10 miles to warm oil up to temp
    Aug 2013
    14
    Quote Originally Posted by Iceash View Post
    Hmmm, mines Deffo not reading right ;-)
    Dec 2013
    Aberdeen
    32
    My coolant temp is around 90 and oil sits between 70-90 and when I drive normally I get around 30mpg and fuel saving mode is around 30-40.. On a good day...
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    90 / 90 here, it will affect MPG if the engine is running too cool, as will tired MAF's and 02 senders
    Jun 2011
    71
    My coolant temp is 90 and oil temp is 80 - thats after both a new oil pump and coolant pump fitted new oil and the larger oil filter, takes a while for the oil temp to get up in winter, cam chain tensioner is also new, and power steering pump too !!
    Aug 2013
    14
    Quote Originally Posted by matt66604 View Post
    Hmm, 30-40 mpg. Most ive managed is 24.8 so I'm thinking some is definitely not right. My corrado g60 used to get more MPG than my b5 :-( I love it but it's costing a lot to run. Gonna run my code reader over it 2mrw and see what it picks up
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    Mine also sits bang on 90 for both oil and water. The best I've had for a decent trip (150 miles'ish) is 32mpg but have achieved 36mpg on a shorter trip once according to the display.
    Edit: Mine starts warming up and the water gauge moving after approx 3 miles.
  1. Running Temp Issues
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2007, 19:15
  2. A4 TDI 110 running temp?
    By rob1380 in forum General Technical / How To
    Last Post: 4th July 2007, 17:20
  3. Lower than normal running temp and lower mpg....
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2007, 11:24
  4. Right running temp of s4 1993 2226 engine
    By Rev-head in forum Classic Audi Forum
    Last Post: 26th October 2004, 22:12
  5. A-6 2.7T running temp???
    By Jims5543 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th June 2004, 16:31
