EM TuningMonster Motorsport
Results 1 to 16 of 16
Like Tree2Likes
  • 1 Post By B5 BIKER
  • 1 Post By desertstorm
Thread: Intermittent temp gauge.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Hi all,
    had the stat changed as I was getting odd temp readings. As it climbed it would fall suddenly, then climb higher then fall again. It would eventually get to 90 then maybe now n then drop to say 70, hold then climb back to 90. The 49c would mirror this also on climate con. Could this be the cts? Or something else?
    thanks,
    Ash
    myth's Avatar
    Dec 2012
    88
    Definitely the CTS. If you have a vag com, surely it will throw a code.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Quote Originally Posted by myth View Post
    Don't have access to vag com. Can't be anything else then?
    Is it something Audi keep on the shelf?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,871
    Mine did this a while back when i fitted a new temp sensor and thermostat !! I would be driving on motorway and it would drop to 70' then slowly creep back to 90' left it alone to see how it got on and its never done it since !! Both were genuine audi parts !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Been doing it for weeks now, new stat fitted today. Fitted the higher temp one though. Engine and oil nice n toasty.
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    235
    Definitely the cts mate
    Iceash likes this.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Audi likely to carry one on the shelf?
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    235
    Ya they get changed that often they normally would
    2 different versions though. 2 pin or 4 pin
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Quote Originally Posted by B5 BIKER View Post
    Has 4 wires coming out of it so assume 4 pin. So other than feeding temp to dash gauge. What's its purpose?
    Nov 2013
    Heath Hayes
    637
    Very common fault across almost all VAG cars 97-2005 ish.
    GENUINE VW COOLANT TEMP SENSOR SENDER AUDI A2 A3 A4 A6 A8 TT S3 059919501A | eBay
    Old design CTS will be black new design ones are green.
    Closer to £30 from the dealers. They should have them is stock.
    Karl.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Funnily enough, I went through 3 in 5 years on my 6n polo!
    Aug 2010
    2,871
    That one is the newer style 'D' shaped two pin sensor you need the old square style 4 pin one thats green they are what audi supplys and have superseded from the old blue square 4 pin sensor !!
    But double check as some late TQS's have the 'D' shaped green one !!
    Nov 2013
    Heath Hayes
    637
    They have 4 wires because there are two seperate temperature sensors in there. One supplies the ECU the other the dash for the temperature reading. One or both can be intermittent. Quite often you only notice because the temperature gauge starts going like a windscreen wiper.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    I had a D shaped one, changed surprise surprise. All works lol :-D
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    235
    Good stuff, I had to change mine on my old A4, even my A6 now needed one also so it must be fairly common.
    Both sides were shot, needle used to jump around and the ecu sensor also it used to make the engine run uneven and bring on the esp light
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Thankfully she behaved other than using a little more fuel. However when the one on the Polo failed it kept reving which was scary when trying to engine brake lol
  1. Car cutting out when turning right and temp gauge intermittent
    By tommytonguedj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd August 2012, 11:26
  2. A6 temp gauge intermittant
    By elite installations in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th September 2011, 22:11
  3. A6 2.5TDI V6 temp gauge falling and rising??
    By imported_Auditurbo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th June 2005, 00:44
  4. Help with my Temp Gauge
    By XXX_18T in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2004, 09:53
  5. A3 temp gauge
    By adjturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 19:45
