AH FabricationsVolks Autos
Results 1 to 9 of 9
    Aug 2013
    The 'carse of Gowrie.
    80
    Transmission oil changing
    Guys, is there any DIY guide anywhere about replacing the gearbox and diff oils with oil specs as well for a quattro?
    thanks
    Mo.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,875
    Gearbox - 75w90 fully syn @ 2.75L
    Rear diff - 75w90 fully syn @ 1.9L
    Youll need the big 12 point spline socket to drain them both !!
    Filler plugs -
    Gearbox - 17 or 19mm sump plug key iirc
    Rear diff - 8 or 10 mm allen key iirc
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Jul 2007
    338
    Always make sure you can get to / undo / have the right size tool for the filler plug BEFORE you remove the drain
    1999 Audi A4 1.8TQS (Standard)
    2003 VW Golf GT TDi
    2002 Audi S8 4.2 SOLD
    2004 Alfa 156 2.4JTD 20V Veloce SOLD
    2000 Audi A4 2.8 Quattro tiptronic (Electric heated seats, winter pack, lowered on H&R Springs & 18" A8 sport wheels) SOLD
    1999 Audi A4 1.9TDI 110hp (with full Audi Sports kit) SOLD
    Aug 2013
    80
    Oh yes indeed
    Aug 2013
    80
    Aug 2010
    2,875
    You dont need to remove the drivers wheel or passenger for that matter it can be accessed easily without removing the wheel as the filler plug is on the n/s on uk cars !!
    The fill plug for rear diff is on the drivers side on uk cars !!
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    244
    Better links here for B5 rear diff gear oil change and transmission. Note they're US.
    Rear diff: AudiWorld Tech Articles
    Transmission: http://www.audiforums.com/forum/diy-...sandman-18729/
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Aug 2013
    80
    Aye those are far better.
    How about this, Motul Gear 300 75W-90 Racing gearbox and differential lubricant, for both box and diff?
    I can work my way around engine oil but the gl4/gl5 specs for gear oil need adhering to.
    cheers
    Mo.
    Aug 2013
    80
    Any takers for the [still sealed 5l] of millers TRX synth 75w-90 I unearthed from the back of my cool dark garage today ?
