AH FabricationsChris Nott
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    A4 sill trims when fitting S4 sides
    Hello folks, I have a pair of S4 skirts that have been in my garage for years. Thinking I maybe should get the finger out and get them fitted. I know I need to remove the A4 sill trims but can I refit after I have the skirts on?
    I guess they will need trimmed down along the lower edge. Is it easy to remove them and refit without damaging them?
    A4 1.8T Quattro, FMIC, Coilovers, B&M short shift, 312mm Brakes, Stage 4 clutch, Awe Gauge, Uprated antiroll bars, plus more bits. Pics Here
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,873
    I removed mine completely till some cheap S4 ones come up !!
    You can probably trim them whilst on the car but you may struggle at the b pillar, and yes they are a pain to remove them there stuck on with good old german adhesive
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Guys, you might be waiting a while for S4 ones to come up. I tried removing mine recently and it seemed like there was no.chance of them.coming off cleanly in one piece. Ended up sticking them in the bin because they were in such bad shape once off, and that was with me being careful.
    Mo power, mo problems
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    Great thanks chaps. Think may be best to try trimming on the car in that case as I do not want to lose them.
    Jun 2013
    Montrose, Tayside
    77
    Steady hand and a dremel to trim them, that's what I plan on doing when I fit mine
