WHY DOESNT THIS SITE ALLOW MY POST TO BE ADDED WITH PUNCTUATION AND SPACES I HAVE ADDED TO ALLOW EASY READING AND UNDERSTANDING OF THE SUBJECT CONCERNED????????Before everyone shouts use the search button, I have and there are so many conflicting reports, some allude to be A4 fitment and turn out to be S3 so not the same at all etc so please bear with me................................................................................................................................................................I have just fitted to my late 1998 A4 Avant B5 AFN TDi, a Double Din Dash and an Audi S4 RNS E and have a few queries..............................................................................................The swap is a Double Din from a facelift 2001 A4 to my car, I have a couple of questions relating to the wiring of the eqpt and the interior temperature sensor, RNS E unit and I hope you can assist....Firstly, the fog light switches for the facelift dash, can you just wire these in to the stock wiring with the relative spade connectors? I have seen it mentioned that to have it 'stock' I need the fog light module, is this correct??... .. All I want is to turn the fog lights both front and rear Independently of each other when I feel the conditions warrant using them.................................................................................................................................................................................. Are the Facelift switches compatible with the pre facelift wiring and does anyone have a colour coding/wiring diagram/picture for the switches??.....................................................................................................................................................On the interior temperature sensor there is a small motorised sensor installed in the centre of the dash on the pre facelift.................................... Now, on the facelift there appears a sensor in the centre of the dash in the same area, but where as the pre facelift has two pairs of wires going to it, it appears that the facelift has only one pair going directly to the motorised sensor... I have left my pre facelift sensor wired in albeit under the dash out of the way, but I wanted to know if the facelift needed to be wired in in order for the facelift climate control to function correctly or would the signals be received from the old sensor unit be suffice? ........................................................... Does any one have an alternative wiring solution to wire the facelift unit to the two pair of temperature sensor wires the pre facelift unit has?.....................................................................................................................................................................................................................................I have fitted a 2007 RNS E unit to the car. It works fine but have a few irritating problems.............................................................The unit only operates on operation of the button on the unit, not when the ignition key is switched on, or when removed, it switches off the unit. I purchased a plug n play loom from ISO to Quadlock for the unit so the wiring should be correct.....................................................................................................Is the on/off operation just a VAGCOM adjustment? An american forum stated that they needed a can bus box but I thought the UK AFN was non Can-bus.......................................................................................The CD auto changer does not work but I think this might be down to the wiring not being included in the quadlock connector, not a major problem as I can trace the correct Pinouts for the connector at a later date.....................................................................................................................................................................................................................The bottom line of lights for the function buttons do not light up with the side light switch, again is this a VAGCOM adjustment or is there an extra module of some sort required?...The screen dimmer function doesn't seem to work, is this VAGCOM adjustment again?..................................................................................................................................................And there seems no Clock adjustment on the unit...,,,I have fitted the Fiscon Basic Pro kit and I understand that to get their kit to work, I need VAGCOM to change the settings in the RNS E........................................................................................ Has anyone done this and know what the new values should be? There weren't any settings included in the box.................................................................................Has Anyone done the VAGCOM changes on this unit??...I am near Ashford Kent at the moment and can travel if anyone has a vagcom unit they can assist me with making the necessary adjustments..........................................................................................................................................................................................................Thanks in advance, Look forward to enjoying the new unit more than I am able now....
