Monster MotorsportEM Tuning
    Nov 2013
    7
    Brake pad wear sensor wiring
    All,
    My 2000 A4 has always had the brake pad wear light on, though the pads were good.
    I did new disks and pads a while ago, and got the pads with the wiring connectors on.
    My car has the bracket to carry the connector, but no sign of any cable or connector car side. I presume they've been cut off. So I still have permanent brake warning light.
    Can anyone tell me where the wires go in the wheelarch? Are they part of the same cable as the ABS sensors?
    Thanks,
    R
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,872
    Just soft code it out with vagcom !!Someones probably fitted abs sensors without pad warning !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,905
    Cant softcode it out on the later clusters.
    You can connect the sensor wire to ground at the back of the clocks to get the light off.
    TD5 Land Rover Defender build
  1. Audi brake pad wear sensor
    By spartacus 68 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th July 2012, 23:11
  2. Front brake pad wear sensor lead?
    By rockape in forum A3/S/RS Parts
    Last Post: 6th December 2011, 13:14
  3. Pre-facelift S3 brake pad wear sensors or not?
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2011, 17:50
  4. Replies: 15
    Last Post: 27th May 2008, 20:41
  5. front brake pad wear-indicator wires!
    By imported_tractorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2005, 09:55
