Volks AutosBadger5
    2,168
    Running a wire from the engine bay to the passenger side of the car
    I need to run a cable from the engine bay to the passenger side foot well, the cable is a fixed length so I cannot route it via the ECU box, the cable is also about 10mm thick.
    I did a quick forum search as I was hoping to see a couple of write-ups but came up blank, anyone help with this or know of a good thread.
    jcb
    Sep 2005
    uk
    4,077
    in car transformer?
    get down to halfords and get a decent set of jump leads to replace the fixed length cable
    plenty heavy enough if that is what it is for
    not worth the hassle of going through the firewall when there are so many holes by the ECU/Fuse board?
    2,168
    No not a transformer, but it is 240V the cables have special water proof connectors so cannot be cut or modified.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    What are you trying to do?
    I certainly wouldnt be drilling holes in my bulkhead for some accessory!
    TD5 Land Rover Defender build
    2,168
    Just run a cable in the cabin, its why I asked if anyone else had ran cables in before. Decided to go in via the passenger side wheel arch through one of the grommets. Far better solution than putting more holes in the car.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Can it not be routed through the box where the pollen filter is? I had thought that the bulkhead had the same 'holes' on both sides so that Audi could get away with producing a single shell for the LHD and RHD markets, ie: where our pollen filter lives is where a LHD car's ECU is.
    Mo power, mo problems
  1. How to rev the engine from the engine bay
    By RobMorris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th June 2012, 14:32
  2. Funny noises from the engine bay and maybe something draining the battery.
    By danpayneuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2010, 11:08
  3. How to get wires from the engine bay to the cabin? A4 B7
    By Richardesty in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th December 2008, 14:15
  4. Access to the engine bay through the firewall in an 8P S3?
    By cooni in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th May 2008, 13:22
  5. Help, tick tick coming from the engine bay?
    By imported_ashs3 in forum Tuning
    Last Post: 5th June 2005, 13:23
