Sky InsuranceVolks Autos
    ashley1's Avatar
    Aug 2011
    Haverfordwest, Pembrokeshire
    53
    Looking for S4 advice...
    Hi guys, I'm looking for an S4 saloon, preferably nogaro blue. New to B5s, so anything I should look out for? Thanks in advance!
    My Progess Blog < Click!
    Audi A4 B7 S-line Avant 2.0 TDi Dolphin Grey
    19x9.5 3SDM 0.05, Airlift Bags with Autopilot V2, Custom Boot Install with Sub, Black S-Line Grille, LCR Splitter, FR&R Tuning Remap
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    244
    Quote Originally Posted by ashley1 View Post
    Probably a petrol station! The S4 drinks like a fish, but that's par for the course with any petrol V6. Any reason for a saloon in particular rather than the avant?Like anything, you'll need FSH and lots of receipts. The B5 has a timing belt unlike the B6 timing chain (which is an engine out job). Make sure the belt is is replaced (every 60k or 4 years) along with the water-pump, and a genuine thermostat. Probably worth doing the auxilliary belts while you're at it.Things to consider will be complete suspension refresh using Lemforder or Meyle HD arms (if car is over 100k), renewing or exchanging rear brake calipers (prone to siezing). Front brakes are twin-pots. Also check turbos spool up with no lag. Any hesitation then usual culprits are vacuum and breather pipes which are prone to splits, etc.Paint should be better on B5 model, but usual places are front arches if you're checking.I'd get the car scanned with VAGcom so at least you're aware of any stored faults. Probably a worthwhile investment on what can be an expensive car to maintain, given high insurance and running costs as a daily runner.Good luck.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    ashley1's Avatar
    Aug 2011
    53
    Brilliant, thanks very much! It would be a second car, so fuel economy and sensible things like that don't really matter!
    jcb
    Sep 2005
    uk
    4,070
    oil leaks
    rocker cover gasket and or oil feed lines to turbos....
  1. New S3 Owner looking for some advice...
    By S3RYE in forum The Welcome Section
    Last Post: 10th June 2009, 16:27
  2. Looking for interior advice
    By The G-Man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2009, 13:39
  3. Howdy, looking for some advice
    By gtiandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2008, 15:53
  4. Looking for some advice
    By L60N in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2008, 22:20
  5. NEW A4 owner looking for some advice
    By hardeep1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2006, 10:40
