Badger5JMB Retrofits
    jcb
    Sep 2005
    uk
    4,077
    dead viscous fan
    anyone ever pulled one and left it off?
    is this a lock position job?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Spanner on the front to lock it off and then a 8mm allen key (I think, not sure on the size) in the ass end to remove it.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    We took the fan off my brothers S4 and it was fine.
    We left the two electric ones in place and made sure they were working, and they did a fine job.
    My TQS also has its viscous fan removed, and only has the small electric fan fitted, and again it keeps the temperature under control just fine in the UK climate.
    Might be a bit worried if you were planning on climbing mountains in europe in 35c heat, but for the UK, so long as the electric fans are functioning you'll be fine.
    You have the option of either just removing the blades part, and leaving the hub and pulley fitted, or removing it all and fitting a shorter belt. On the 1.8T i removed it all, i cant remember what we did on the S4, but i think we might have left the pulley as it made the belt routing easier.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    BMW lads have been doing this for years with no issue and they run 6 pot petrols.
    A diesel would be fine I suspect.
  1. broken viscous fan and now RADIATOR! really???
    By TeKnodriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2011, 10:38
  2. A6 Allroad viscous fan always on
    By Mazi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th September 2009, 17:43
  3. Removing Viscous Fan
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th June 2009, 10:12
  4. Noisey viscous fan?
    By andybnwc in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th November 2008, 16:57
  5. Viscous fan bearing
    By Stringster in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2006, 08:29
