EM TuningChris Nott
Results 1 to 28 of 28
Like Tree2Likes
  • 1 Post By spartacus 68
  • 1 Post By bouncer117
Thread: Front abs sensor
    Aug 2012
    telford
    211
    Front abs sensor
    Does anyone know how to remove a front abs sensor as mine won't budge
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    Quote Originally Posted by bouncer117 View Post
    Assuming its faulty and you're replacing, you may end up having to drill it out. I'd remove the hub so there's no chance of damaging the ABS reluctor ring.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Aug 2012
    telford
    211
    Yes sensor is faulty. Is there no way without taking the hub off?
    Dec 2008
    Aberdeenshire
    254
    Chances are it will disintegrate once you start to work on it. The hub is easy enough to remove. You can release the hub nut, then the splined bolts on the driveshaft (transmission). Turn the steering wheel and you should be able to drop the drive shaft down and out. That will give you peace of mind that no debris gets onto the reluctor ring, etc. Use a little grease in the aperture when fitting the new sensor.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Lots of Plus Gas, a small pry bar and a set of mole grips.
    Mo power, mo problems
    Aug 2012
    telford
    211
    I take it I need to remove the caliper and disc before spraying?
    Aug 2012
    telford
    211
    Quote Originally Posted by spartacus 68 View Post
    Does it matter which direction the steering wheel is turned?
    Dec 2008
    Aberdeenshire
    254
    Shouldn't do. From memory if it was the driver's side, I'd probably turn the steering towards kerbside. Incidentally, if you go down this route, renew the hub nut. These are normally renewed as part of the CV boot, given the torque you need to use to shift it. You'll probably need an extension pipe on a 1/2 ratchet drive. Could kill two birds with one stone, does CV boot need done? Any cracks are an MOT fail.
    I used to recommend GKN driveline kits, but they wear prematurely after a couple of years. A genuine Audi boot is probably better.
    Aug 2012
    telford
    211
    The boot looks quite fresh but I will give it a closer look while im there
    Aug 2012
    telford
    211
    Will I be able to release the hub nut with the front end up on stands. Just put a couple of bolts back in and get someone on the breaks?
    Dec 2008
    Aberdeenshire
    254
    No, do this with the wheel on the ground. Take the alloy wheel cover off (covering the wheel bolts) and get an impact hex socket on it with a 1/2 ratchet drive bar. Some hub nuts are Allen bolt variety. If that's the case - then I can recommend Laser tools which are excellent. I use a length of scaffold tube on the bar for leverage.
    More details here: AudiWorld Tech Articles
    Incidentally - there's no need to touch the strut pinch bolt, turning the wheel works. Another tip - don't hit the CV joint with a steel hammer to remove it from the driveshaft, only ever use a rubber mallet.
    Aug 2012
    telford
    211
    Ok ill giv it a go thanks
    Aug 2012
    telford
    211
    Just had a look at the boots they're not split but starting to crack a bit you recon they changing?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    If there cracking then they havent got long left !!
    the sensor will have a rubber boot, pry this upwards and spray WD down then use some pliers and work the sensor turning it back and forth then gradually pull out from the hub use more WD if necessary !!
    Dec 2013
    32
    i done mine last week had to smash it to bits then burn the inner bit that was left out so you dont damage the hole thats the last thing you want to do
    Aug 2010
    3,136
    The uprights have a brass insert so as long as you dont go overkill and butcher the upright you can just clean things up and fit a new brass insert !
    Aug 2012
    telford
    211
    Do I need to remove the hub completely or just drop the driveshaft out?
    Aug 2010
    3,136
    Id say you only need to remove the wheel and maybe the brake discfor a little more room !! If you be patient and dont get frustrated and start to snap/hammer things then you can gently work it out with some WD and maybe abit of oil/diesel !!
    Aug 2012
    telford
    211
    Yer I have tried that and im getting no movement at all
    Aug 2012
    telford
    211
    Do I need to replace the hub bolt?
    Aug 2010
    3,136
    It is recommended yes as its a stretch bolt iirc
    Aug 2012
    telford
    211
    Ok do you know where I could get one on its own? I can only find them as part of boot, joint or bearing kits and although the boots could probably do with changing I don't have the time to do them at the moment
    Dec 2008
    Aberdeenshire
    254
    Remove the brake carrier, caliper and disc and secure on wire support or bungee cord. You just need to undo driveshaft splined bolts and hub nut, not the hub itself.
    bouncer117 likes this.
    Dec 2008
    Aberdeenshire
    254
    The GKN kits include everything. In my experience they're good for 2-3 years. Audi boots are better. Changing the boot on the CV joint is going to add another hour tops. Well worth it if you're removing brake components and driveshaft. Means everything will be sweet as a nut once you remove ABS sensor. Other main thing is that once CV boot splits (and it will) and normally when you least expect it, the CV gets contaminated (loss of grease and grit gets in) and you'll end up having to replace the CV too.
    Aug 2012
    telford
    211
    I was thinking this but what I thought was going to be a 15 min job on Saturday is stil ongoing, knowing my luck at the min ill take it apart and find that the joint needs replacing too
    Aug 2012
    telford
    211
    Do I need to take the caliper off aswell? Sorry for asking so many questions but this is the 1st proper job I have done on a car
  28. #27
    Dec 2008
    Aberdeenshire
    254
    Yes, I would.
  29. #28
    Aug 2012
    telford
    211
    All done now. Thanks for all the help and advice. Had to cut the end of the sensor off then knock it through to the inside after removing the driveshaft then because only the middle came out slowy chip the case of the sensor and the copper cage out. Also changed the cv boot which luckily was hassel free. Thanks again everyone
    spartacus 68 likes this.
  1. Todays problem - Front ABS sensor replacement
    By wysiwyg in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2012, 12:16
  2. ABS G45 Front Speed Sensor - Fault
    By Watty in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th August 2010, 23:53
  3. front abs sensors
    By mattmackenzie in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2010, 18:21
  4. A4 B5 Front ABS/speed sensor.
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th July 2010, 11:29
  5. 2001 S3 Front Offside ABS Sensor Part No ?
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2006, 16:03
