Chris NottBadger5
Results 1 to 12 of 12
    Nov 2005
    Nottingham
    36
    Help needed in fitting an amp.....
    hi there, just wondering if anyone fitted an amp into the their car, and if so where did you find a hole to feed the power cable from the battery to the inside of the car?
    I had a look myself last night, but could'nt see any holes?
    Any help would be great!
    cheers
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    Re: Help needed in fitting an amp.....
    there is (i think) a gromet behind the glovebox. im not sure though as im yet to tackle said event in the audi.
    imported_billybravo
    be carfull where you stick you hole or you will have a swiming pool in your car
    when i bought my audi the owner before me must of had a amp in it he stuck the cable where the bonnet pull cable goes but he didnt seal the hole so water got intothe car it took me a long time striping the dash and making the the hole water tight
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,522
    The best place is the ECU box, put a slit into the grommet from under the bonnet and run it thru there. As its so accessable its dead easy to seal up. I have 0wg in mine no problems
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    Mine comes through under where the pollen filter is and it comes through behind the glove box then i ran it under the trim on the passenger side of the car.
    Then under the rear seat into the boot.
    madkebab's Avatar
    Dec 2003
    South West
    396
    Same as Mawhitey - This is the best route. Power down right of car, RCA cables down the left.
    Jul 2005
    2,488
    absolutely. keep the power and signals seperate.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    I would say pop open the ECU box and drill a whole in the bottom of the casing feed the cable up into there and then straight in to the car near the fuse box and then straight to the rear via the seal.
    Phantom_A4's Avatar
    Jan 2006
    Southwater, United Kingdom
    562
    I ran my power cable through the hole in the off side wing where the bonnet mount is, and through the passenger side with all the wiring. It requires a bit of water proofing, but no drilling etc is required!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    The only drilling is to the plastic casing for the ECU.
    Jun 2003
    World of my own
    9,813
    You don't need to drill the ECU at all there is a spare grommet already there made for the job.
    Nov 2005
    Nottingham
    36
    cheers guys for the help, will give it a go tomorrow morning
    cheers
