Results 1 to 11 of 11
    Jul 2007
    341
    Tell me about 312mm brake upgrade...
    I need to sort new discs and pads all round, so this is a prime opportunity to upgrade. The 312mm setup seems popular, but does that extra inch make all the difference?
    Is it a worthwhile upgrade? Also, what pads are people using?
    1999 Audi A4 1.8TQS (Standard)
    2003 VW Golf GT TDi
    2002 Audi S8 4.2 SOLD
    2004 Alfa 156 2.4JTD 20V Veloce SOLD
    2000 Audi A4 2.8 Quattro tiptronic (Electric heated seats, winter pack, lowered on H&R Springs & 18" A8 sport wheels) SOLD
    1999 Audi A4 1.9TDI 110hp (with full Audi Sports kit) SOLD
    Nov 2013
    Heath Hayes
    951
    I upgraded 288 to 312 on my B5.5 Passat and it was a worthwhile upgrade. As for pads I used to use EBC Yellow stuff, bit dusty but they worked very well. Red stuff is not as dusty.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,088
    I did this a couple of years ago now. It's only a small size change but so worth it. I was allready using Brembo brakes from nextdaybrakes and they were ok. I used a set of carriers from a B6 A4 iirc and set of Brembo discs from a 3.0 B6 A4 iirc and then teh pads with a set of B5 A4 Brembo pads, the improvement was really worth having. With Bardahl synthetic brake fluid my brakes are pretty good now and stand up quite well to track abuse.
    Life begins at 140mph
    www.passionford.com
    Jul 2007
    341
    Cool.
    I do hill climbing and sprinting (not in the A4! that was acutally bought as a daily / tow car), and most people use green stuff, or mintex 1144 (which are about twice the price). Greenstuff changed there make up which saw a lot of people migrate to yellow stuff to get the same results. Green stuff now alegedly back to how it used to be. People dont tend to go any more extreme than this, because you start to loose the cold bite which is vital in a sport where your launching into the first bend on relatively cold tyres and brakes, and only have a min or two to make it count.
    wheres cheapest to get the carriers? seen places selling them new for £140 new. Used seem quite sparce. Didnt realise B6 A4 carriers would work too, might be eaiser to find.
    2003 VW Golf GT TDi
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,088
    To be honest I am gobsmacked anybody uses Greenstuff as they're utter toilet. Had countless issues on road cars, thought of competion use with them frankly scares me.
    I know I paid £15 for my carriers, it was either a B6 A4 or an A6 they came off.
    www.passionford.com
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    B6 A4 has the larger carrier spacing, you need TT/S3 carriers and B6 3.0 quattro discs, then just use existing calipers and standard A4 pads !!
    griswold's Avatar
    340
    Had my A4 for years before going 312mm setup should have done it before feels so much better.
    The wife's A6 c5 has 312mm brakes so i'm sure the carriers from that will work too as they are the same pads and I already had a spare set of discs.
    So might be worth checking a A6 c5 v6 breaking
    So I think any vag 312mm discs will do not just B6 3.0 discs
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,384
    Be aware that C5's after 2001 use the bigger spacing, same as the B6, so are no use unless you use the later uprights too.
    TT and S3 are the easiest sources of the B5 fitment ones, but a lot of breakers will only want to sell you the whole caliper, and they know that they're the ultimate bolt on upgrade for A3 and Golf folks, so they can hold a premium.
    You need to retain the B5 caliper, as the pistons bigger than the TT/S3 ones. Use B6 3.0 disks, and standard B5 pads.
    Forget the EBC crap, if you want road use pads just fit a set of Ferodo Premiers.
    TD5 Land Rover Defender build
    Jul 2007
    341
    The EBC pads we are using are about 8yr old atleast, I have heard that they arnt what they used to be.
    Will track down some quality road pads.
    The carriers are taking a bit of finding to get them for a sensible price.
    2003 VW Golf GT TDi
    Aug 2010
    3,138
    griswold's Avatar
    340
    Just to be clear, I used the 312mm discs from the A6 c5 not the carriers
    A6 2.4 Avant SE
  1. 312mm brake upgrade advice!?
    By MAD_Adamski in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2009, 12:09
  2. 312mm brake upgrade
    By Shug1874 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2009, 16:15
  3. 312mm Brake Upgrade - How To?
    By MikeA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2007, 13:50
  4. My 312mm Brake upgrade.
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2005, 22:45
  5. About rear brake upgrade.
    By Theodore in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 07:51
