Chris NottEM Tuning
Like Tree1Likes
  • 1 Post By aragorn
Thread: So does it make sense to uprate the injection nozzles
    Jan 2012
    Malton
    279
    Following the tuning a tdi threads recently it did start me thinking.... So would the sensible cost effective route be
    Uprate injection nozzles - where to buy nozzles?
    Remap
    Then when funds are available and the wife isn't looking get a pd 130 turbo and fit that ....
    What is the collective wisdom?
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un. Quality Cambelt kit fitted - next on list is control arm set.
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP - but she lives on in the many,many donor parts she gave so that others may live...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    I presume yours is a PD engine?
    I believe the 115 PD injectors will flow around 150-160ish.
    The simplest thing to do would be to swap in some 130PD injectors, which are good for 230. But you'll need a remap to suit the larger injectors i suspect.
    Its pointless doing things in the order you suggest. Get the turbo (i'd use a BV43 rather than a PD130 unit, as theres more scope) and the 130 injectors, fit them together and get it mapped and you'll see a nice solid 190-200hp.
    Tom_B likes this.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,997
    What about the inlet manifold?
    I know the PD130/150 manifold is recommended for the AFN engine, is it the same for the AJM?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    15,370
    probably, if it has the **** manifold, then fit the PD130 one.
    Jul 2007
    London
    3,235
    Early AJM injectors are no different than pd130 injectors and they flow about 440cc per minute. The limiting factors on the 115bhp engine are the intake, rods and turbo, they are same spec as the 110Bhp jobbies. Also they came with different gearboxes, some had a variant of 01E gearbox even though they were 5 speed and the small 228mm clutch. The early pd115 are some of the quirkiest cars in VAG range i came across and every time i do a clutch job on them i do replace like for like by comparing the parts i take off with what i fit !
    FOR SALE:
  1. water profits - does this make you cross?
    By imported_CurryMilkShake in forum General Chat
    Last Post: 1st June 2006, 22:37
  2. Could you uprate the................
    By The Slug in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2006, 15:52
  3. Making a monkey of the diesel myth
    By PaulRS3 in forum General Chat
    Last Post: 28th September 2005, 23:03
  4. does anyone know how to replace the Lambda sensor?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2005, 23:26
  5. does optimax make a difference?
    By viper in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2003, 22:56
