Monster MotorsportVolks Autos
Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By Bradderz_1988
Thread: Tell me about..... airbag modules
    Jul 2007
    338
    Best start a new thread for this rather than high jack the other. Mines playing up in my late 99 TQS avant. fairly sure it's the modules, the light takes a while I go out when its cold, which from what I've read is the module.
    Are they model specific, i.e. Tied to certain specs or engines? Or will any old one from a FL a4 do the job?
    Do they need coding when changed?
    Anyone got one for sale?
    1999 Audi A4 1.8TQS (Standard)
    2003 VW Golf GT TDi
    2002 Audi S8 4.2 SOLD
    2004 Alfa 156 2.4JTD 20V Veloce SOLD
    2000 Audi A4 2.8 Quattro tiptronic (Electric heated seats, winter pack, lowered on H&R Springs & 18" A8 sport wheels) SOLD
    1999 Audi A4 1.9TDI 110hp (with full Audi Sports kit) SOLD
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    There are different types, depending on if you have curtain airbags etc, best bet is to whip out your ashtray and get the number off yours and then see what's about. If you get the same no coding should be required.
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,871
    Or just wizz vagcom on and read the part number from the controller !!!
    if you get same part number then they might have same coding but just jot it down before you whip it off !!
    PAULF likes this.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Jul 2007
    London
    3,074
    Wished i seen this post earlier, scrapped 2 facelifted a4 b5 and left the controllers in ! One had curtains airbags, the other was just 2 dash+ 2 seats...
    FOR SALE:
    Jul 2007
    338
    I dont have VAGCOM unfortunately. I read somewhere that I need to get a 'soft code' off it before I swap it?
    I cant find any good guides on getting the ash tray out to gain access. anyone?
    2003 VW Golf GT TDi
    Jul 2007
    338
    Got it: AudiWorld Tech Articles
    looks like if I slide somthing down between the climate control and the side of the centre console the climate will pull out, and then I can hopefully see the module, or get toe the ashtray bolts.
    Hopefully this is the same for the single din on mine.
    2003 VW Golf GT TDi
    jcb
    Sep 2005
    uk
    4,070
    PM sent
    have one from my 99 TQS Avant
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    I think you pull the trim around the radio and climate towards you, go gentle there a little delicate, then you open the ashtray and you should see 2x 10 mm bolts at the top corners, then the ashtray should slide out, there is also an illumination cable for the ashtray that you need to disconnect.
    then you should just about see the module between two black ducts. Should be an orange and white sticker.
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    It is a bit tight so if you need to pull the climate out to see it has four metal retainers on each corner, but doesn't have removal keys like a stereo! I'm sure on my single din I just gave it a healthy pull from both ends and it came out, it's a bit easier with single din as you have something to grab hold of when the facia is removed.
    Jul 2007
    338
    Excelent - thanks. Does the Headunit need to come out first? EDIT; read it again, sounds like head unit needs to come out, then the trim, then climate. I may be able to see down in with a mirror or camera with just the headunit out. Im only trying to get the part number off it at the moment.
    JCB - PM back at ya.
    2003 VW Golf GT TDi
    Jul 2007
    338
    Mines a 8D0 959 655 J
    Waiting to hear back from JCB as to the part number on his. In the mean time, anyone else got one? Ethereal are lots of others for sale but the only 'J's are refurb'd ones for £200. I assume I can't use a 8D0 959 655 or similar in its place, and it has to be the J version.
    2003 VW Golf GT TDi
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    I believe for the facelift there should only be a j or an f type,
    i have an f in mine as it's got curtain bags, I sorted bradderz with a j for his tqs, I'm pretty sure he didn't have to do any soft coding, and was just plug and play,
    That was saloon to saloon, I don't know if there may be weight calcs defined by the soft code that differ saloon to avant or vice versa
    Jul 2007
    338
    Thanks to JCB I have one on the way. Will postpone the MOT until saturday or Monday (when it actually expires) which will give me a chance to fit it. Awesome.
    2003 VW Golf GT TDi
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    The only difference saloon to avant AFAIK is the centre belt pretensioner.
    If you fit an avant part to a saloon you'll get a fault code about the missing middle belt tensioner unless you change the softcode to say you dont have a middle rear belt!
    TD5 Land Rover Defender build
    Aug 2010
    2,871
    Quote Originally Posted by Sulli79 View Post
    correct plug and play as the soft codings were identical, used vagcom to double check though !!!
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    That makes sense! Jcb had an avant so if you have a saloon it will need coding, check the vagcom map if you don't have it and hopefully someone local can help you out, unless you do have an avant then no drama.
    Edit: you do have an avant so all good!
    Jul 2007
    338
    yup! Sounds like I'll be all good!
    its still going for its MOT tomo, but they are aware that it misbehaives until warm. Retest on Saturday morning if if fails, with the new module fitted. what a faf!
    fingers crossed it will be OK anyway.
    2003 VW Golf GT TDi
    Jan 2012
    Malton
    272
    Take it for a good Italian tune up before you go to make sure it's all nice and hot and cleared out for the emissions test.
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    Aug 2010
    2,871
    Looking at my iphone notes your soft coding should be 16487 if that helps !!
    Jul 2007
    338
    I don't have vag com, so I'm preying its plug and play!
    i have a cheap eBay USB cable, but never got it to talk to the free version of vag com.
    Defo getting a good Italian tuneup beforehand!
    2003 VW Golf GT TDi
    Aug 2010
    2,871
    Whats your issue with vagcom ??
    If you have cable id get that sorted then you can do this task and also diagnose other faults in the future !!!
    "Stick a V8 in it!"
    14,904
    yeh its usually just a com port issue
    Drop me a PM and i can talk you thru getting the ebay lead working.
    Jul 2007
    338
    Well its passed OK. Advisory on the discs, but I knew that - planning a 312mm upgrade, just need to find the carriers.
    I spent ages playing around with my ebay lead with no luck when I had my first A4 a few years ago,and gave up.
    Aragorn, thanks you for the offer, thats very kind. I'll send you a PM.
    2003 VW Golf GT TDi
  1. trying to get airbag module repaired
    By dubmas in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2007, 20:23
  2. fun with airbag module...
    By Bascule in forum General Chat
    Last Post: 22nd June 2007, 17:00
  3. Telling insurance about mods
    By Jay in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2007, 09:29
  4. Anyone know anything about airbags?
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2007, 21:42
  5. Tell us about the new Audi-Sport.net
    By AL_B in forum Site Support & Announcements
    Last Post: 20th June 2006, 12:43
