JMB RetrofitsEM Tuning
Results 1 to 17 of 17
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    List of mods and figures AHU 90
    Hi all, I was at scottyb5's last night sorting out my dials, when he said it would be an idea to ask if anyone has a 90 like myself, and see if they could list the mods they have and how each one effected it's power (figures) thanks all
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,365
    TBH the first thing you need to do is get it converted to VNT turbo, then you can tune it like any 110 engine.
    With the right bits you can see close to 200hp.
    TD5 Land Rover Defender build
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    That's a big job is it not? Got to change all sorts just to get the turbo in there manifold ecu ect
    "Stick a V8 in it!"
    15,365
    yeh but without it theres little scope or point doing anything.
    The stock turbo is tiny, and will limit you to around 120hp.
    120hp can be achieved with some bigger injectors and you'd probably get away without even remapping it.
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    What I have done is a decat full muflerectomy air filter does nothing anyway lol, and I am having a chip done next week (plug n play) what do you think I have roughly?
    "Stick a V8 in it!"
    15,365
    I'd leave the chip and fit 0.216 or 0.230 nozzles instead. At least that way they're not wasted if you do decide you want more in the future and upgrade to a VNT turbo, and you'll get a similar result.
    With the 0.216's and a bigger turbo you might see 160ish.
    The 230's will go a bit more.
    Darkside have the 230's for £150.
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    I can get 216 from a pd130 a4 can't i? (All b6's) and how hard is the job to do?
    "Stick a V8 in it!"
    15,365
    No, the PD injectors are totally different.
    The 0.216's are fitted to 5 cylinder transporter vans.
    Or you can buy the nozzles new from somewhere like Darkside. If you buy the nozzles, you probably need to have them installed into the injector body by a pro, as they need set up. Once you've got the assembled injector, you simply remove the old ones and fit the new ones, a fairly basic spanner job.
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    What injectors are in the b6 as people have said to take the injectors out of them.
    "Stick a V8 in it!"
    15,365
    B6 uses a unit injector system called Pumpe Deuse.
    This has individual camshaft driven pumps mounted on top of each injector.
    They are completely different to the setup on your engine, which has one large rotary pump connected to simple mechanical injectors by some steel pipes.
    PD Injector:
    http://www.volkswagenspares.com/User...20(Custom).jpg
    VE Injector:
    http://img.photobucket.com/albums/v7...s/Audi/269.jpg
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    My brain aches!!
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,335
    Pahaha just do as Aragorn says to achieve a recepie for success.
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Lol, il try :S
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Does anyone have a set of these they are not using?
    "Stick a V8 in it!"
    15,365
    there are 0.216 nozzles on ebay:
    VW PASSAT B4 B5 1.9 TDI 0.216 NEW INJECTOR NOZZLES SET OF 4 DSLA150P764 | eBay
    As i said before though, you'll need to get a derv specialist to install them onto the injector bodies
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    I did see them on eBay and was just asking if anyone had spare. I look into it Aragon as I don't know of anywhere that will do it in Cornwall
    "Stick a V8 in it!"
    15,365
    There will be somewhere around that can do it, or you can use a mail order service like this:
    https://www.darksidedevelopments.co....l-service.html
    If your expecting to find used ones then i'd maybe try tdiclub, much more TDI stuff happening over there than on here.
  1. A list of mods for the 1.8t and a small review on each one
    By zeeeebo in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2009, 19:44
  2. Facts and Figures But Whats The Cause
    By basscrazy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2008, 00:10
  3. Forget the mods and fancy options!
    By jdp1962 in forum General Chat
    Last Post: 27th January 2006, 08:58
  4. MN - Mods and Rods 3: A whole new show!
    By imported_DNeinstadt in forum Events outside the UK
    Last Post: 4th August 2005, 16:47
  5. The Mods and Rods Charity Car Show!
    Last Post: 9th July 2004, 20:04
