Hi all, I was at scottyb5's last night sorting out my dials, when he said it would be an idea to ask if anyone has a 90 like myself, and see if they could list the mods they have and how each one effected it's power (figures) thanks all
What I have done is a decat full muflerectomy air filter does nothing anyway lol, and I am having a chip done next week (plug n play) what do you think I have roughly?
I'd leave the chip and fit 0.216 or 0.230 nozzles instead. At least that way they're not wasted if you do decide you want more in the future and upgrade to a VNT turbo, and you'll get a similar result.
With the 0.216's and a bigger turbo you might see 160ish.
The 0.216's are fitted to 5 cylinder transporter vans.
Or you can buy the nozzles new from somewhere like Darkside. If you buy the nozzles, you probably need to have them installed into the injector body by a pro, as they need set up. Once you've got the assembled injector, you simply remove the old ones and fit the new ones, a fairly basic spanner job.
B6 uses a unit injector system called Pumpe Deuse.
This has individual camshaft driven pumps mounted on top of each injector.
They are completely different to the setup on your engine, which has one large rotary pump connected to simple mechanical injectors by some steel pipes.
