Badger5Sky Insurance
Results 1 to 8 of 8
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    Does anyone know..?
    I have a 99 facelift 1.8 that has the older dial clock on the cluster, im looking to replace the engine with the one from a car im breaking, also a 99 but with digital clock on the cluster.
    if i take the loom for the later engine and fit it to my car, how much rewiring will be required, if any to make it work?
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Has your current car got oil level sensor in the sump?
    Edit: This might help a bit as well.
    A small project
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    Quote Originally Posted by ScottB5 View Post
    A small project
    No oil level in the current car, i was thinking that the mid facelift clocks probably dont support the oil level so it may be that i just fit the original loom to the replacement engine, and leave the oil level redundant.
    that or fit the entire loom from the other car, which im not sure i fancy!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    PFL clocks don't have a oil level sensor and their oil temp sensor is in the engine block somewhere and their revs are not done via canbus.
    FL clocks have/use and need the oil level sensor and oil temp sensor that is in the sump. They get their revs via canbus signals from the ECU.
    There are other differences between the two but the above is the main stumbling block.
    You can fit FL clocks in a PFL B5 but you need to rewire the plugs and add one or use an adaptor loom (Like what I'm running). You will also need to add the oil level/temp sensor in the sump and change the adoption to use immob 2 instead of 3 to get the revs working.
    Its not a massive job. its only a weekend job really if you have everything already.
    You will need a key coding to the clocks as well.
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    I may have confused the situation a bit! I'm not really looking to fit clocks, I want to fit a full facelift engine loom/harness to a part facelift. Both cars have the same ecu part no, I just need somebody to confirm if it will be ok due to the differences in the looms
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Why is it just the loom that you want to fit?
    I don't think there is much difference between the two.
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    When I removed the engine I left the loom attached, I believe a few sensors have different connections, so if the ecu's read the same info through the same pins it's quicker for me to just swap engine and loom as one unit.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    No, you really need to keep the original loom, as the oil sensor wiring is different.
    You could keep the facelift loom, but the oil temp guage wouldnt work.
    Thats also assuming the pinouts at the bulkhead are the same, but i'm fairly sure they are.
    I think it would be easier to simply swap the loom over, yes a few sensors have different plugs, so just swap those as well.
    TD5 Land Rover Defender build
  1. does anyone know how to replace the Lambda sensor?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2005, 23:26
  2. Does anyone know a good BMW oem parts supplier?
    By imported_Yaseen in forum General Chat
    Last Post: 18th October 2004, 13:05
  3. Does anyone know when....
    By jasew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2004, 16:34
  4. Does anyone know if R88PER is on holiday
    By abmunro in forum General Chat
    Last Post: 15th August 2004, 17:56
  5. Does anyone know....
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2004, 09:39
