AH FabricationsEM Tuning
Results 1 to 21 of 21
Like Tree2Likes
  • 1 Post By Bradderz_1988
  • 1 Post By foursprungdugtechnique
Thread: Rear wheel bearing
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Rear wheel bearing
    How hard is it to do a rear wheel bearing? Garage wants 150! Nearly fell over!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    FWD rears are pretty easy! Its just a pair of taper bearings mounted inside the brake disk.
    TD5 Land Rover Defender build
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    What will I need to get them out. If I order rear disks, what's the odds off getting bearings in them?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    You won't.
    You'll need discs, pads, bearings and just in case ABS rings.
    That I got when I did mine. O and a rebuild kit for the rear calipers and new bolts.
    Personally, I don't think 150 is to bad. Its not a BSD job but it's just a pain if you don't have a press.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    She needs a bearing, but it's 150 then the cambelt 250 and 170 for a cv boot
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    You dont need some thing mega to put it in with using new discs, it becomes a b****** of a job pressing one out thats been in there for a good while and has a huge upright with it !!
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Oh ok, what would do it then? Need grease obviously lol
    Aug 2010
    3,138
    £170 FOR A CV BOOT !!
    do it yourself just make sure you have a strong arm (hub bolt) and the correct clamp pliers for the clips and it will cost you less than £100 with tools !!!
    Aug 2010
    3,138
    Quote Originally Posted by Gunny110 View Post
    vice with socket similar size to bearing or you could try something like a metal g clamp and a suitable sized spacer, you will need some circlip pliers to remove the circlip and maybe some WD or similar !!
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    That doesn't seem to bad tbh, I think I could manage it, I found bearings on eBay for 12 pound or so, is that around what is expected to pay for them?
    "Stick a V8 in it!"
    15,388
    The rear bearings can be tapped in with a hammer and big screwdriver.
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Aww that's easy!! Lol
    Aug 2010
    3,138
    use SKF, FAG OR SNR !!
    spartacus 68 likes this.
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    As above, use decent quality bearings. Cheap ones won't last.
    i got mine prepressed in the discs with abs rotors from car-bock.de, can't recommend them highly enough
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    279
    I was around 300 for both rears, discs, bearings, ABS ring, pads all done. I'm a great believer in just replacing everything at the same time, less labour costs overall
    matt66604's Avatar
    Dec 2013
    Aberdeen
    52
    You can get the rear discs with the bearings allready installed from eurocarparts... You probably will still have to swap abs rings though...
    Aug 2011
    199
    If it's like the front ones, then a press is essential. I know this, having just watched my mechanic replace one of the fronts after just over a year! To say I wasn't happy is an understatement, especially as they wouldn't do it under warranty as that was 12 months! A "German bearing" was apparently used last time - although not an Audi one at £100 or so. I go the replacement for cost, but still had a £120 bill - 1.5 hours labour overall - and it was, because I watched it. I'd certainly not try without the press. Mike.
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    On car-bock.de the full rear set pre assembled - discs,bearings,abs rotors, and pads for €129 (approx £100)
    Don't think that's too bad for German quality parts
    Jan 2011
    279
    Had a look at that site, next time I need discs, that's where I'm going
    B5 BIKER likes this.
    matt66604's Avatar
    Dec 2013
    Aberdeen
    52
    Yeah I try to stay away from eurocarparts personally... They are cheap.. But you pay for what you get... And everyone knows how crap cheap bearings can be... Caliper repair kit for €8... Mint... I like this site
    Dec 2013
    7
    the abs rings can be removed if your careful, just use a gas torch to heat it up and gently persuade it off, don't try forcing it or it will bend then its only good for the bin I pressed the bearings in one side at a time with a mechanical coil spring compressor and a windy gun just remember to put both outer races in first then the inboard bearing then the inboard bearing race before installing the inboard oil seal otherwise you will never get the inboard bearing and inner race past the oil seal
  1. Rear Wheel Bearing?
    By mattcole2206 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th August 2009, 22:00
  2. a4 2.5tdi quattro rear wheel bearing
    By willieigs in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st July 2009, 09:14
  3. interior mats/rear wheel bearing
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2009, 20:14
  4. Replacing rear wheel bearing
    By Leon in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2009, 14:47
  5. Rear Wheel Bearings on an 8L S3
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2008, 18:48
