Results 1 to 10 of 10
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    Drivers window opened on its own
    I woke up this morning to find my drivers window open and the seat soaking wet! This has happened before with the same window. I've heard that vag csrs sometimes have an issue with this. Anything I can check/do to stop this happening again?
    Jun 2011
    Great Melton Norfolk
    1,349
    Get it scanned to see where/what fault is would be best option.
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    I have an eBay cable. Would this be up to the job?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,376
    TBH, its usually driver error.
    I've done it myself when getting out the car accidentally clipping the window switch. In my case it was on the passenger side, and i only noticed it because i had a passenger getting out at the same time who said "WTF?" and i realised i'd mashed the button when opening the door.
    Theres no magical fault that can cuase it, and theres no ECU or fault codes to scan.
    The window motors are only powered upto the point where you close the drivers door, so they cant magically power themselves up and wind down after you've closed it and locked the car.
    There are only two ways to open the drivers window, one, with the switch, and two, via the central locking module. However the locking module opens ALL the windows simultaneously, so that rules out any fault there...
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,087
    I've had it twice on mine and can absolutely rule out the squidgy organic bit as being as fault. Locked the car and wiped some bird poo off the window. 2 hours later my Mrs comes in and says window is wide open.
    Life begins at 140mph
    www.passionford.com
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Ive had this before now never looked into it just presumed it was 'driver error' !
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    This happened to me on the drivers and passenger window but only cause I've touched the buttons as I was getting out of the car.
    Never seen it happen any other way.
    I have heard some of the new models doing it but that happened to all windows not just one, so assumed they had skinny hipster jeans on and it pressed the open button on their remote.
    Can't think why it would randomly happen either.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    boost-addict's Avatar
    Aug 2011
    977
    this happened to me, drivers window open over night with it pissing down outside
    but thought it was me that left it open which i was 99.99% sure i didnt.
    intresting!!!
    LPG Abuser & have VAGCOM
    Aug 2005
    Essex
    180
    Yay - I have inadvertently knocked the switch on mine .... good thing I live in a nice neighborhood !
    Jan 2012
    101
    This used to happen on my MK1 TT and has happened a couple of times on the A3, really worrying.
  1. Windows opening on their own!?!
    By daver555 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st August 2011, 13:32
  2. Electric windows opening on there own
    By rog190quattro in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th April 2010, 18:16
  3. Boot opens on its own?
    By bobby_southward in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2010, 15:08
  4. Drivers door open when its not!!
    By Nilz in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2008, 12:39
  5. Passenger window opening on its own!!!
    By S3K in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2005, 19:46
