Badger5Monster Motorsport
Results 1 to 13 of 13
    boost-addict's Avatar
    Aug 2011
    977
    part numbers needed.
    hello all.
    got a clutch and now a timing belt to do, so taking the engine out, so going to do a few other things, ive found a few numbers but im struggling to find the rest
    gearbox mounts
    engine mounts 11811141377 (is there a diffrent one for left and right?)
    rear crank seal
    gearbox input seal
    clutch release bearing
    clutch slave
    cam belt kit (can someone suggest a decent one?) thinking a gates or continental kit
    oil pump
    metal impeller water pump
    oem thermostat and temp sensor
    clutch slave pn:8D0721257
    brake master cylinder reservoir pn:8E0611301
    flywheel to crank bolts (to fit audi 80 flywheel)
    clutch cover to flywheel bolts
    any thing else worth doing as per course?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Aug 2011
    977
    thanks scott. any ideas on the best cam belt?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    Quote Originally Posted by boost-addict View Post
    No idea mate.
    I tend to just give my car the mech and go fix it. lol
    Aug 2011
    977
    lol, fair enough, i know gates is good, but wondered if that was a prefered source in the vag world.
    Aug 2011
    977
    lol went to those links, all a load of gibberish to me
    cant make head nor tails of the menus to get to the right section
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    I used a Contitech belt kit. It came with all the right bits and all OEM brands.
    From memory a TQS needs CT919K4
    TD5 Land Rover Defender build
    Aug 2011
    977
    great, found one in ebay for that, the rest of it i have no idea, i did email jason @ all german car parts but not had any info back from him, i gave the same list and asked for a quote.
    will have to just do lots of googling and try and find the right parts
    are engine and gearbox mounts diffrent from left to right?
    "Stick a V8 in it!"
    15,391
    yes, engine and box mounts are sided, Lemforder do the box ones for sensible money, Jason should be able to get you those. The engine mounts are fairly pricey as they're hydraulic.
    Aug 2011
    977
    yer no new back from him, sure he will he sorted me out that clutch cover
    the ones i found under the part numbers were rubber?
    "Stick a V8 in it!"
    15,391
    Also, dont obsess over getting a pump with a metal impeller, just buy a decent quality pump.
    ****e pump with a metal impeller will spit its bearings out after a week. Decent pump with a plastic impleller will last years.
    Why are you changing the temp sensor and slave cylinder? Slave is external on the A4 and so i wouldnt bother unless it was broken. Temp sensors almost never fail and are almost always misdiagnosed.
    "Stick a V8 in it!"
    15,391
    The engine mounts are rubber with hydraulic stuff inside.
    Aug 2011
    977
    because the one i bought is suspect wasnt genuine, and im changing the slave becasue while ive got it out and to be fair, if im doing all this other stuff then i may as well, not looking forward to it as much as the same to fitting new arms and bushes/top mounts back and front next
    oh i see
  1. OE part number needed!!
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2008, 08:11
  2. part number needed
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2008, 12:58
  3. Part Number Needed - B6 Cabriolet
    By loafy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th January 2007, 21:53
  4. S3 Clutch VAG Part Number Needed
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2006, 12:52
  5. Help Part Number Needed
    By simonwjones in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd August 2006, 21:01
