Chris NottEM Tuning
Results 1 to 17 of 17
Like Tree5Likes
  • 2 Post By aragorn
  • 1 Post By Tom_B
  • 1 Post By aragorn
  • 1 Post By Gunny110
Thread: Aftermarket air filters
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Good for mpg or no?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,299
    Will make no difference.
    At least until they ruin the MAF sensor.
    TD5 Land Rover Defender build
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Ruin the maf sensor? Really?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,109
    If you run an oil based filter it coats the MAF in the oil thus damaging the sensor, ive been toying with the AEM dry flow filter as theres no need to oil them, but i run the k&n 57i kit at the minute with no issues and i never oiled it neither.
    all you really gain is more audible induction/spool noise from the turbo !!
    "Stick a V8 in it!"
    15,299
    Quote Originally Posted by Bradderz_1988 View Post
    And SIGNIFICANTLY poorer filtration. Especially with unoiled ones.
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    253
    I run a standard K&N panel filter. Never had an issue with the MAF (touch wood). I clean the filter with the detergent spray (let it soak for 30 mins), then rinse with warm water, then let it dry thoroughly. Filter only needs a very light mist with the oil spray before reinstalling. Saved a fortune not having to buy disposable air filters.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Mar 2013
    Southampton
    128
    Hi,
    Oilled performance filters, only contaminate the MAF if they are not maintained properly, over oiled and/or oiled on the wrong side of the filter, I have used K&Ns and BMC filters for well over 200k miles now on my Audi, and my Mercs with only one MAF issue this occurred within a few hundred miles of fitting the filter, replaced it and have had no reoccurrence that was over 100k miles ago now.
    Regarding performance economy improvements, C230K improved the MPG slightly, performance negligible, C43 AMG (55 AMG Engine fitted) no discernible economy improvement, performance it did seem to make an improvement but not sure whether this is just a placebo effect, as the filters give it a real throaty induction noise through the twin cold air intakes. My Audi 3.0TDI Cab, I have noticed neither performance or economy improvement.
    I only fitted the filters in the first place to eliminate the expense of OEM filter replacement, the AMG filters for example are £117 to replace as opposed to £60 once only for the K&Ns.
    Mar 2013
    Southampton
    128
    Hi,
    Regarding performance economy improvements, C230K improved the MPG slightly, performance negligible, C43 (55 Engine fitted) no discernible economy improvement, performance it did seem to make an improvement but not sure whether this is just a placebo effect, as the filters give it a real throaty induction noise through the twin cold air intakes. My Audi 3.0TDI Cab, I have noticed neither performance or economy improvement.
    2,149
    I'm sticking with OEM paper filters, you don't need to pi$$ around with buying cleaner & oil (wondering if you have put to much or to little on on the filter), waiting around for the filter to dry & oiling it before putting the car back together! All Audi's RS range run paper filters if it's good enough for them then it's good enough for me.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,071
    I've run K&N air filters on every car I've owned without ever having a problem. I did replace my MAF a few thousand miles ago but the fault turned out not to be the MAF. I am cautious on my A4 as I no fouling the MAF can ruin it so give it the odd squirt with electrical contact cleaner. Done about 70k miles since fitting the filter on it.
    Life begins at 140mph
    www.passionford.com
    "Stick a V8 in it!"
    15,299
    I just dont see the point.
    The stock paper filter flows 380hp perfectly happily on an RS4, so why make the engine bay look **** with some skanked in cone filter, plus run the risk of MAF damage and worse air filtration.
    It seems to be something that every young guy with a modified car does, they dive in and stick a stupid airfilter, stupid dumpvalve, and a rediculous exhaust on, and pronounce the car is now better. Then i drive past them with my standard airfilter, standard exhaust, and standard dumpvalve, because i spent the money on tyres instead.
    Jan 2012
    Malton
    276
    don't hold back Kev, just say what you really think....
    ScottD3 likes this.
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    "Stick a V8 in it!"
    15,299
    lol, i didnt mean it as a dig, its just a pointless modification IMO.
    There are no positives of fitting one, it achieves only negatives, and is a complete waste of money.
    LPG Abuser & have VAGCOM
    Aug 2005
    Essex
    171
    Hahhahah can't believe it... there is a K&N ad at the bottom of this thread!!!
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Lol, shame you can't like comments
    aragorn likes this.
    "Stick a V8 in it!"
    15,299
    you can...
    Gunny110's Avatar
    Jul 2013
    cornwall
    233
    Not on tapatalk
  1. A4 TDI 110bhp Recommended Aftermarket Air Filter / Induction Kit
    By CHR15 B5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th August 2010, 10:39
  2. Aftermarket Air Filters - As good as you think?
    By kaz219 in forum General Automotive Chat
    Last Post: 10th September 2009, 12:10
  3. New A3 Upgraded Air Filter Offer
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2004, 15:10
  4. Air filters induction kit on S3
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th October 2003, 17:02
  5. New air filter?
    By BarryT in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2003, 08:44
