Badger5Chris Nott
Results 1 to 11 of 11
    Aug 2012
    telford
    211
    anyone know what fault code 17966 is?
    as above does anyone have any idea what fault code 17966 is? as its not on wiki ross tech
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Got more details on it?
    Did you use VCDS to get the code?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Aug 2012
    telford
    211
    na just code reader
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Aug 2012
    telford
    211
    do I need vcds to do a tba?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Yes you will need vcds/vagcom !!
    2,169
    A quick google gives the following error. 17966 - Throttle Actuator (G186): Electrical Malfunction
    Aug 2012
    telford
    211
    where would people recommend to get a cheap cable from? I bought 1 a while ago off ebay, but it doesn't fit (the 16 pin plug is too big). I already have the programme just the cable needed
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by bouncer117 View Post
    I had the same issue but I trimmed the area around the port a little bit with a knife and its fine now.
    Aug 2010
    3,136
    Yeah mines not the best fit either, will go in with a little wiggle though no need to trim anything !
    Aug 2012
    telford
    211
    ill give it a go and see what happens. thanks
  1. does anyone know what engine code i can put in my a4 sline thanx
    By turboscarface in forum General Automotive Chat
    Last Post: 29th April 2013, 23:01
  2. Does anyone know what these codes mean?
    By m444ty p in forum VCDS (formerly VAG-COM) forum
    Last Post: 29th November 2009, 01:10
  3. anyone know what an N75 valve is on a TDI engine?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2006, 22:25
  4. Anyone know what Ive got ????? - Clean Responses Please ;o)
    By Geronim0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2005, 22:20
  5. DO anyone know what this may be A4 ??????
    By imported_SIR_WHITEY in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd April 2005, 10:00
