Chris NottEM Tuning
    Apr 2010
    48
    Which size rear pads? Different heights.
    Seem to have two options.
    Have a B5.5 1.8 avant.
    Option 1. Thickness: 16,6, Width: 87,6, Ht: 67,5
    Option 2. Thickness: 17,2, Width: 87, Ht: 53
    The height options are obv different.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    There are two b5 pads, and the only difference is the type of retaining spring.
    If you have iron calipers you want the "droopy" springs, if you have aluminium calipers you want the "sticky-up" springs. It makes sense when you look at the two pads.
    Post the part numbers your looking at and wether your car has alloy calipers or steel.
    TD5 Land Rover Defender build
  1. Which rear pads to use? Im heavy on the brakes .
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd August 2012, 11:12
  2. Changing Rear Pads and Discs on S3
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2007, 22:59
  3. Rear pads 80% worn - how many miles left?
    By Rich in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th January 2007, 07:52
  4. 2.6 rear pads lucas or teves?
    By ste8270 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd December 2006, 22:13
  5. Which discs and pads???
    By Ben_yo in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2006, 21:12
