GabeRossi
My build...Already have a Write-up on Audizine..click on the link---->http://www.audizine.com/forum/showthread.php/381087-GabeRossi-s-Build-Thread[/URL]
Not much of an active member on this forum but I am trying to be. I figured I would share what I am doing to my B5 this year, and I hope to get some positive feedback on my build but haters are welcome Usp Motorsports has been my #1 shop for my car enthusiasm, they have done some of the greatest work to Euro cars I have ever seen! I got the car 3 years ago and encountered many complications along the way, and now I am finally ready for this build...being a very active automotive college student and employee at VEI Systems I do not have the time to build this car myself and I want it done perfect, which is why I chose Usp Motorsports.. Anyways here is whats going in...
I will be updating this as everything goes along
Engine:
AEB 1.8L
JE Pistons
IE Rods
ARP Head Stud Kit
Main Bearing Set
Rod Bearing Set
Thrust Bearing
Head Gasket
Crankcase Gasket Set
RS4 Motor Mounts
034 Transmission mounts
034 Snub Mount*NEW 2013
Turbo/ECU:
Pag-parts turbo kit(manifold,hardware,lines,gaskets,Intake)
Precision 5857 Dual Ball Bearing Turbocharger all v-band
Oil feed/return lines
Eurodyne Maestro
Forge 007 DV
Tial MVS Wastegate
Precision 600hp core w/ custom Usp Motorsports Inter-cooler Piping
MAF/Harness
Greddy Profec B Electronic Boost Controller** NEW 2013
Fueling:
830cc Injectors
bosch 044 fuel pump
***Just converted to ethanol UPDATE 11/11/2013
E85 Setup:
ID 1000cc Injectors
Radium Surge Tank w/walbro 400E85 Built in pump and regulator
Lines and fittings
Integrated Engineering Fuel Rail
Exhaust:
Custom Usp Motorsports 3in Down-Pipe/3in Down-Pipe back exhaust
Drivetrain:
Clutch Masters 725 series Twin Disk Clutch w/pedal stop**NEW 2013
Raxle - Drive Axles
Brakes:
Audi A8 OEM BBK 288mm-312mm **NEW 2013
Hawk Ceramic Pads
Got a pic of the Turbo
If you want to follow the build also check out Usp Motorsports Facebook page
I did some detailing on my car today and the paint came out like glass, figured some of you will enjoy these pictures....some are blurry but forgive me it was taken on my phone
quick cell phone video
snapped a few today on my digital cam came out surprisingly well, enjoy
and a friend took this yesterday
Engine:
AEB 1.8L
JE Pistons
IE Rods
ARP Head Stud Kit
Main Bearing Set
Rod Bearing Set
Thrust Bearing
Head Gasket
RS4 Motor Mounts
Turbo/ECU:
Eurodyne Maestro
Forge 007 DV
Tial MVS Wastegate
MAF/Harness
Fueling:
830cc Injectors
bosch 044 fuel pump
E85 Setup:
ID 1000cc Injectors
Lines and fittings
Exhaust:
Drivetrain:
Raxle - Drive Axles
Brakes:
Hawk Ceramic Pads
