Chris NottSky Insurance
    Nov 2013
    9
    failed thermostat - inline replacement?
    hi all, i have a 2.5 tdi audi a4 b5 and the thermostat has failed, i am not prepared to take apart the whole front end of the car but am aware of inline mods that can be done, i am pretty sure my top radiator hose wont accept a thermostat from a renault 5 or volvo 340 as it is not big enough, so can someone point me in the right direction for an inline housing unit that will do the job? or is there a 28mm diameter thermostat out there that could fit inside my hose?
    many thanks in advance
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    TD5 Land Rover Defender build
    Nov 2013
    9
    aragorn have you done this mod? if so where do you buy the parts from/
    many thanks
    "Stick a V8 in it!"
    15,388
    No, but paul has, i believe he got the housing from some sort of mini website, its linked in the second post above.
    Nov 2013
    9
    thank you, have sent them an email, trying to cheap the cost as low as possible but my fuel economy is really taking a hit so needs sorting... many thanks for your help
  1. Temp gauge issue after thermostat & sensor replacement
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2013, 23:01
  2. FAILED / failing Tandem pump, replaced or advised to??
    By JimC64 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 26th April 2013, 11:23
  3. thermostat replacement......help
    By cornish_a3_turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2008, 22:10
  4. Replacing the thermostat
    By grumbas in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2008, 14:43
  5. Thermostat replacement
    By robonmac in forum Classic Audi Forum
    Last Post: 1st April 2007, 23:17
