EM TuningChris Nott
Results 1 to 13 of 13
Like Tree7Likes
  • 1 Post By aragorn
  • 1 Post By adamss24
  • 1 Post By @udi A3
  • 1 Post By PAULF
  • 1 Post By PAULF
  • 1 Post By spartacus 68
  • 1 Post By PAULF
Thread: Not Again!
    Jan 2011
    Aberdeenshire
    635
    Not Again!
    Oh well,
    Going in to work this morning and it appears the Avant dropped a valve.
    Nasty noises, seized (not turning over) engine and oil on the floor.
    Just to add to the joy, my one is off the road at the moment whilst I get around to the timing belts and ancillaries.
    The alternator belt went and as the belts were due in November on calendar time, I started the job in slow time. I have all the rollers, belts etc, but can't spare any time to progress it until later next week at the earliest.
    £45 taxi to work later and now a 2 day hire of a poxy 107.
    Really angry as we only fitted the engine into the Avant 40,000 miles/ 3 years ago after a zero hours overhaul from Vege Engines.
    Not too sure where we will go with this one, Mrs PaulF is more than a little fed up with it and we are looking toward binning the car. Which would be annoying after all the work we have done to it.
    Although at least it could be a spares donor for my saloon.
    I might have a look at engines first though.
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    Stick a PD130 into it.
    I wouldnt waste my time on the V6.
    TD5 Land Rover Defender build
    Jan 2011
    Aberdeenshire
    635
    I'm not going to be bothered buggering about swapping over to fit something else Kev and to be fair I really do like the V6.
    The saloon showed me how they should be!
    We're just going through options at the moment - bearing in mind I can't keep a hire car long due to the road I'm on will destroy them!
    "Stick a V8 in it!"
    14,949
    i hear what your saying, but the v6 just doesnt seem to be a great engine, they're heavy, thirsty and have a whole host of reliability issues, a lot of which you've had.
    Buying a used engine is a minefield and the replacement you buy is just as likely to develop some fault given their nature. If it were an inherently reliable engine with a one off unlucky failure then sure, i'd be saying dive right in with a used replacement motor.
    I'm sure, when running right, they might well prove to be a good drive, but their negatives seem to overwhelm that.
    PD130 on the other hand is like the polar opposite. Might not be an exciting engine, but it has almost the same output, gets the job done and they just go on forever.
    I guess if you dont want to convert the B5, then look into a B6 quattro, or a Passat 4motion that come with the engine already? Unfortunately from what i've seen theres a massive price chasm between what you have, and the later quattro models that came with the PD130 engine. The bottom has fallen out of B5 prices, whereas the B6/Passat models seem overpriced in comparison.
    That said, simply slinging a used engine in gets it back on the road immediately for minimal cost, so maybe that does make some sense to take a risk on it if you can get one cheap enough...
    "Stick a V8 in it!"
    14,949
    Converting to the PD130 you mean?
    Wouldnt need to touch the transmission or shafts, the PD motor would bolt right up to the existing box. Passat or A6 engine mounts will fit right onto a B5 no problems there.
    The tricky bits would be the plumbing and possibly the wiring, though the right era cars do share a lot of that and having a donor car would give you pretty much everything you need.
    I can see his point though, even if its fairly straight forward, its still a significant hassle over just bolting in another similar engine.
    PAULF likes this.
    Jul 2007
    London
    3,091
    Most likely the engine broke a rod, especially if the rebuilder used the same big end bolts... A dropped valve would not puncture the block or sump so no oil should leak on the floor... It's unfortunate but things do happen... Paul, if you need a good AFB engine then drop me a line, i am breaking 2 cars so have all the parts you might require...
    PAULF likes this.
    FOR SALE:
    May 2012
    RETFORD, NOTTS
    1,718
    If you go for a pd130 i know a guy in sheffield breakng cars all the time, if you want details let me know. I say this as he would be able to provide any loom and other parts you need, he also turns the immo off on a lot of ecus which may be a help to the conversion initially.
    PAULF likes this.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jan 2011
    Aberdeenshire
    635
    Thanks guys,
    I'm not going to put in a different lump - too much hassle (Thanks Kev and @udiA3). I might go for another AFB (thanks Chris I may take you up on that) or bin it -I don't know yet.
    The problem is what that new bloke (ScottyB5) said - there's a lot of good, known bits on that car.
    Because the saloon has been so good, I know how the engine should perform.
    I've learnt a lot since I paid to get it overhauled - the main thing being don't pay to get it done by somebody else (Present company excepted of course, Chris!)
    Meantime I may have the chance of a 1.9 (I can't remember the reg but think it was PFL) for £580. It'll keep me going for a few weeks until I get time to finish my timing belt and then I have the option to resell it or break it. I'll talk it over with Mrs PaulF first.
    ScottD3 likes this.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    That was me mate. 2nd account as this one was having issues.
    Hope you get it sorted mate.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Jan 2011
    Aberdeenshire
    635
    Quote Originally Posted by ScottB5 View Post
    I thought that mate, but I modified my first reply just in case it wasn't you!
    ScottD3 likes this.
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    245
    Not so good Paul. There's always something, and it's never at a convenient time. I know what you mean about the V6 when it's running sweet, plus considering the time, money and effort you put into your cars, the temptation is fix it when others are saying to walk away or change the engine.
    Keep us posted and hopefully you stay with the old girl. I don't want to be the only Audi Sport B5 V6 owner in the immediate area!
    Sub 100k Audi 2.5 quattro avant (aka Amtrak locomotive)... Audi A4 2.5 TDi Quattro 5dr ultimate driving car.
    Only like it because of the colour and has an electric tilt and slide sunroof.
    PAULF likes this.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Jan 2011
    Aberdeenshire
    635
    Quote Originally Posted by spartacus 68 View Post
    Don't worry, I've still got the saloon even if we do decide to ditch the Avant.
    I have bought the 'V' plate (it was a FL) 1.9 2WD saloon to give me breathing space.
    It's bit crap, but it was cheap and is tested for 11 months and taxed for 5. Drives ok, so far.
    I have a shedload of house rework to sort and check out the tractor and then look at my timing belt!
    spartacus 68 likes this.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,988
    Quote Originally Posted by @udi A3 View Post
    whos that ?
  1. Replies: 30
    Last Post: 29th July 2013, 23:22
  2. Not again.....
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2012, 23:33
  3. Cambelts...[NOT AGAIN!]..you might find this interesting...
    By evotista in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2008, 16:31
  4. Not again!!
    By Adams3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2006, 19:09
  5. Not again!?!?!?
    By joost in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th April 2006, 07:25
