Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Tom_B
Thread: urgent window motor help needed
    Jan 2012
    Malton
    279
    my drivers side rear passengers window has stopped working and it has stopped working in the down position. I have taken the door card off and can hear the relay clicking when I actuate the switch but the winder motor does not react.
    So two things - I urgently need to get the window back up before the weekend storms - can I do this manually?
    secondly - does this sound like a motor failure or is there something else causing the problem?
    I had noticed before that this particular window did not fully close when closing all four windows with the fob from fully open. It would go up about 75% and stop when the others would close fully.
    many thanks as always,
    Tom
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un. Quality Cambelt kit fitted - next on list is control arm set.
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP - but she lives on in the many,many donor parts she gave so that others may live...
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,643
    Take the motor out, and push it up manually, then refit the motor to hold it mate.
    Currently rolling in a SKODA!!!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,137
    My windows sometimes stop with a 1-2 inch gap at the top if you can hear the motor engage but nothing happening the sounds like the cables give, but as above take out the window unit remove motor and try close it if it wont budge with the motor removed you will need to cut the cables and then wedge the window shut with a block of wood etc
    Jul 2007
    London
    3,241
    If you need a door frame or window actuator/motor let me know, breaking 2x a4 b5 facelift and one pre-facelift so have all the parts...
    FOR SALE:
    Jan 2012
    Malton
    279
    Thanks Arrkon - the car is now watertight for which I am extremely grateful.
    Do these motors just fail of is there something I can do?
    Jan 2012
    Malton
    279
    cheers Adamss24 - I'll probably want a new motor unit
    boost-addict's Avatar
    Aug 2011
    977
    Sounds like a broken wire in the door shut rubber boot
    Aug 2013
    The 'carse of Gowrie.
    118
    Nice to see folk rallying round with advice etc
    Mo.
    Jan 2012
    Malton
    279
    Agreed Mo, sharing information and support is what the internet is for. That and porn.
    Aug 2011
    977
    Same problem mine had albiet mine was stuck in the up postion. I thiught motor but tried it on the other side and worked. Pulled the boot back and there was a broken power and split earth that had corroded.
    Jan 2012
    Malton
    279
    Cheers man, I'll check that out tomorrow.
    boost-addict likes this.
  1. Heater / Blower Motor help needed
    By Steve_D in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th April 2013, 17:26
  2. cabriolet side window adjust , help needed
    By puma999 in forum Classic Audi Forum
    Last Post: 31st May 2011, 17:24
  3. Urgent help needed, windows stuck down!
    By AndyMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd July 2005, 12:43
  4. URGENT HELP NEEDED... WHAT WOULD CAUSE....
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2003, 07:50
  5. Urgent help needed
    By Stuart_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2003, 09:02
