EM TuningSky Insurance
    Nov 2012
    49
    2.5 TDi not charging - help!
    Hi,
    on my way home tonight I noticed the battery light come on, and the volt gauge dropped to below 12 volts.
    Checked all fuses and they're all fine. Also, VCDS doesn't show any faults.
    Any suggestions before I start shelling out big £££s?
    Thanks,
    Grant
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Knackered alternator.
    Life begins at 140mph
    www.passionford.com
    Nov 2012
    49
    I suspected; are they difficult to change on the 2.5? Could it just be the regulator as well?
    Apr 2011
    63
    If your alternator is valeo you need a whole replacement of your alternator.As they give problem with their rotors,but i expect you have many miles ,so you must change also regulator,bearings,its better to get a whole unit.If its bosch 99% is regulator problem.Hope i helped.
    Nov 2012
    49
    Right; I'll check the make then!
    Back to my original query; is there any quick way to access the alternator without dismantling the front end of the car?
    Apr 2011
    63
    as far as i remember no....
  1. Help, 1.9 TDi not running
    By Gaz! in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th September 2013, 23:42
  2. PLEASE HELP A3 TDI NOT STARTING
    By MAXDEX in forum General Chat
    Last Post: 8th November 2011, 07:36
  3. HELP - Dension icelink plus not charging Ipod
    By marriedblonde in forum In-Car Entertainment
    Last Post: 30th January 2007, 21:15
  4. tdi not starting....... timing problems, any help out there?
    By shufti in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st December 2006, 18:47
  5. Brake Lights not Working!! HELP!!
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2003, 12:41
