JMB RetrofitsSky Insurance
Thread: upgrade bootlid
    davy j's Avatar
    Jun 2013
    Edinburgh
    74
    upgrade bootlid
    hi just got a query
    I have a 1996 A4 B5 with the push button bootlid and was wondering if it is possible to fit a bootlid without the button (with the elecrtric release) without too much hassle
    bootlid i am thinking about is off a V reg model
    boost-addict's Avatar
    Aug 2011
    977
    upgrade bootlid
    I dont see there being a fitment issue.
    Can you not just swap over the switch/mechanics if the push button switch
    Unless you want the different opening style
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    Think its a bit of a 'swap the full CL pump over and necessary wiring' job
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    Yeh the electronic tailgates dont actually lock as such, the central locking pump just ignores the buttons if the car is locked.
    Not an easy job to swap unless your good with automotive electrics.
    TD5 Land Rover Defender build
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Are you just wanting to swap to get rid of the ugly push button? If so, you can easily mod your own boot so that it works from a solenoid. I did mine a few years back. Have a little button hidden under the dash which you use to open the boot.
    Here's a pic of mine:
    Mo power, mo problems
  1. Best Brake upgrade using standard wheels
    By lost_it in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2003, 13:28
  2. S3 Brake Upgrades - not Porsche/Brembo
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 17:05
  3. Brake Pad Upgrade?
    By nicks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 05:19
  4. Final upgrade
    By A4Steve in forum General Technical / How To
    Last Post: 16th January 2003, 17:27
  5. APR Chip Upgrade
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2003, 16:34
