AH FabricationsChris Nott
    Jun 2011
    73
    engine intermittently cuts out
    A4 1999 1.8tqs B5.
    So engine starts and runs fine, accelerates in all gears right through the rev range without any misfires or odd sounds, only seems to happen when slowing down and clutch is depressed to change down into 4th, after driving in 5th for some distance with rev counter around 3000 - 4000, rev counter drops instantly to zero and battery light illuminates, just as if you turn off the ignition. Let the clutch back up and still in gear and the engine fires straight back into life obviously because of the momentum. Any other time the engine is fine and idles at 950 without any irregular movement showing on rev counter, any one else ever encounter this problem ? And what should I be looking for ? It does not always happen - but annoying when it does ! If I repeat the process it does not happen
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Have you scanned for any faults ??
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by Bradderz_1988 View Post
    As above but maybe it's your throttle body or maf you could try throttle body alignment with vcds.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    ignition switch perhaps. Given rev needle drops instantly like engine has been shut off. I guess the crank sensor could be failing, that's the feed to the ecu for revs and then ecu sends feed to dash.. Hmmm VCDS FTMFW
    Jun 2011
    73
    Byzan .........can you tell me what FTMFW stands for - as I haven't got a clue !!
  1. Engine cuts out on full load intermittently
    By cerbera4_0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th February 2013, 20:36
  2. Engine Keeps Cutting Out :S
    By spliffey in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2010, 17:16
  3. Engine Just Cut Out. Please Help?
    By Ronniebiggs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th September 2009, 23:03
  4. Engine cutting out on a mondeo
    By imported_Nigma in forum General Chat
    Last Post: 28th March 2006, 22:58
  5. Engine Cutting Out
    By Masterm8fo in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2004, 09:20
