JMB RetrofitsAH Fabrications
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    FWD Rear Beam Bushes-couple of questions
    I've got a pair of Lemforder rear beam bushes to fit to Vinny,and have a couple of questions.
    1. is fitting them a diy or garage job?
    2.was talking at adi about them,and it was suggested to fill the voids in them.Is this advisable?and if so,what should I fill them with?
    thanks in advance
    Tony
    2,159
    It's not an easy job if you have to do the job with the car jacked up on axle stands. I was going to do this on my motor but in the end handed it to a local garage that I trusted, it only took them an hour to do both bushes, as they had the right tool to press the new bushes in. I also supplied new nuts & bolts.
  1. Rear Beam Bushes - Which Poly Bushes
    By WorkInProgress in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2013, 17:39
  2. Rear beam bushes 2wd 1.8T?
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th June 2010, 11:25
  3. rear beam bush part no
    Last Post: 26th March 2010, 18:57
  4. Rear beam bushes
    Last Post: 15th February 2010, 22:36
  5. S3 rear beam bushes?
    By S3_Driver in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2005, 19:14
