Sky InsuranceAH Fabrications
Results 1 to 9 of 9
Thread: wiring diagram
    2.8 30v's Avatar
    Aug 2013
    berkshire
    133
    wiring diagram
    can anyone help me Iam after the wiring diagram for the brake light system for a 1997 2.8 Quattro avant I can't seem to find one any where
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    What are you wanting to know?
    TD5 Land Rover Defender build
    2.8 30v's Avatar
    Aug 2013
    berkshire
    133
    when I got the car the brake light bulb warning light was on but all the brake lights worked ok.When I started looking into I found that the high level brake light has been wired to the n/s brake light,if I remove the o/s bulb the warning light goes out when I've disconnected the high level light its not working and I've got no power to it I've removed the rear 1/4 trim and checked the wiring from the multi plug to the light with a power probe that's ok so no broken wires in the tailgate.So need to find out if its a broken wire some were and why j have no power to it Just wanting to put the light out if its goin to be a mare of a job, as its poss an mot failure
    2.8 30v's Avatar
    Aug 2013
    berkshire
    133
    I take it no one can help me on were to get a wiring diagram for the brake lights
    boost-addict's Avatar
    Aug 2011
    977
    Centre brake lights isnt a mot failure as not all cars have them
    So are you not getting power to the rear brake light? Have you traced them wires back to any connections. What do you get there?
    Have you checked the earth of the rear brake. Could be an earth rather then a live
    Does a hyanes manual not show the rear light wiring diagrams?
    Aug 2011
    977
    http://www.socals4.com/repair/Bentle...ingDiagram.pdf
    Page 12
    Says black and red wire should power the high level brake light
    "Stick a V8 in it!"
    15,370
    thats for a B6 though, so it wont be quite the same.
    I've got the diagrams at home but i'm at work today so i cant help you just now.
    Aug 2011
    977
    wiring diagram
    Oh. Says a4 b5
    But says 2002 my on the diagram!!
    2.8 30v's Avatar
    Aug 2013
    berkshire
    133
    Cheers for that, i don't have a hyanes,i think the warning light is a mot failure, ive checked the multi plug in the n/s/r 1/4 panel now power to that ive powered the loom up from there and the light works so i need a diagram so i can check the wiring at anyother multiplugs and find were the earth points are
  1. Audi A3 wiring diagrams?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2005, 18:43
  2. Wiring diagram for an S3 (02)
    By Mattytay in forum General Technical / How To
    Last Post: 1st March 2005, 20:40
  3. Alarm/Door connector wiring diagram?
    Last Post: 3rd February 2005, 22:14
  4. audi 100 wiring diagram
    By imported_my_audi_is_brok in forum Classic Audi Forum
    Last Post: 30th January 2005, 17:04
  5. wireing diagram
    By lenin in forum General Technical / How To
    Last Post: 14th September 2004, 17:51
