EM TuningVolks Autos
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By aragorn
Thread: Scuttle panel
    Oct 2013
    17
    Scuttle panel
    Hi, been reading and searching a lot on here and yesterday bought myself a B5 S4, absolutely love the thing.
    One thing I'd like to check is the drainage holes near the battery and the servo.
    Has anyone got any tips on how to remove the scuttle panel?
    I've only had a quick look as stuck in work and tbh only ever worked on golfs so this is pretty new to me and I don't want to break anything.
    Massive thanks
    RACK
    boost-addict's Avatar
    Aug 2011
    977
    yes, remove the rubber and then pull the scuttle panel cover towards the front.
    Oct 2013
    17
    Big thanks mate
    griswold's Avatar
    340
    I'm sure one of the drain holes is under the battery tray
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    2.8 30v's Avatar
    Aug 2013
    berkshire
    135
    there's one under the battery tray and one under the brake servo
    Aug 2011
    977
    i couldnt see mine under the servo :?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    Look harder then! Its there.
    The metal hardline for the clutch goes thru the grommet as well, so if you cant see the hole, look behind the servo and follow the clutch hardline down.
    boost-addict likes this.
    TD5 Land Rover Defender build
    Oct 2013
    17
    Checked this and both drains are clear.
    Checked the sunroof drains and the rears defo need a good clean out as poured water in and some leaked inside. Gutted as no time until next week to get bumper off and clean get some stiff cable up the drain holes
    Jun 2011
    73
    Flexible curtain wires work wonders in drain holes - about 1m long !!
    Aug 2011
    977
    Or buy bike cable wire. Very cheap on fleabay
    Oct 2013
    17
    Thanks guys, got some curtain wire layint about at home so going to try that next week when got the afternoon off work and access to my mates garage
  1. Scuttle Panel
    By Jays Audi Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2010, 10:28
  2. A4 Scuttle Panel Drainageholes
    By DavidBirch in forum General Technical / How To
    Last Post: 9th March 2010, 11:42
  3. how to remove scuttle panel?
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2009, 16:36
  4. Removing scuttle panel trim...help please
    By evotista in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2007, 22:57
  5. Anyone changed a scuttle panel?
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2005, 13:41
